First custom build help.Post Date: 2016-02-11 |
Chromis
Newbie Joined: 11 Feb 2016 Online Status: Offline Posts: 1 |
Topic: First custom build help. Posted: 11 Feb 2016 at 1:49pm |
Budget: It was $2,000, but looks like I'm up nearer $2,500.
Expectations: Reliability. Usage: Gaming and photo-processing Special Needs: None Saved Ticket #: 1368553 Specifications: Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm Bolt 3 Exterior Finish: Black Brushed Aluminum Hairline Finish Side Window: Edge to Edge Premium Acrylic Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: GIGABYTE Z170N-Gaming 5 (Intel Z170 Chipset) (Mini-ITX) (Up to 1x PCI-E Device) System Memory: 16GB DDR4 2666MHz Corsair Vengeance LPX (High-Performance) <br><strong></strong> Power Supply: 600W SilverStone SX600-G (Gold Plus Rated) (Supports up to GTX TITAN X) <br><strong></strong> Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x) Storage Set 1: 1x SSD (250GB Samsung 850 EVO) Storage Set 2: 1x Storage (1TB SeagateWestern DigitalToshiba) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: High Performance Cooler with Five Heatpipes HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Black 120mm Fans Internal Lighting: - No Thanks, Front Panel LED Lighting Only Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Standard Intel Turbo Boost 2.0 Automatic Overclocking Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) The question I have is on the power supply. I thought I needed 850w for this video card? Also, should I be considering a video care with 6 mb ram? |
Quote Reply Posted: 11 Feb 2016 at 2:21pm |
Hi Chromis... What monitor resolution will you be using? For 1080p, even 1440p, a 4gb vram card is plenty. If you want 4K, then the 980ti with more vram would be nice.
That psu is also all you need. 850watt would run sli, 2x gtx 970. Bolt can't sli, so your good. Build looks good. |
Quote Reply Posted: 11 Feb 2016 at 2:29pm |
Just a thought... If you want to save several hundred bucks, pick the Vanquish level 4. You'll get a faster video card, but an i5 vs i7 CPU with hyperthreading. Faster for gaming but the photo work might perform a bit better with Hyperthreading, depending what you do.
