First Time DS Need advice on buildsPost Date: 2016-04-23 |
DarkSideRider21
Newbie Joined: 23 Apr 2016 Online Status: Offline Posts: 3 |
Topic: First Time DS Need advice on builds Posted: 23 Apr 2016 at 8:01am |
About $2400 +- $250 About Me: I wouldnt consider myself a hardcore gamer by any means, I usually game after work for 3-4 hours more or less depending on schedule. weekends tend to be for longer periods of use though that also depends on my schedule. Digital Storm seemed like my best option as i like there customization, Quality, and Hopefully the helpful community! Current Setup: Asus G75VW-BBK5: -Geforce GTX 660M 2GB -8GB DDR3 Memory -1TB HDD Expectations: I would like to be able to play modern and Future games at Ultra Specs or atleast Close to ultra for future games. Usage: Mostly for Gaming, possibly working on a few spreadsheets here and there, possibly use for netflix aswell. Some of my current games are: Black Desert Online, World of Warcraft, Path of Exile, Elder Scrolls Online, Dark Souls 3. Special Needs: Im very used to gaming on a Laptop and not a desktop as i like the portability, even though my laptop is about 9 pounds. That said, I would be willing to switch to a desktop and keep my current laptop as my portable gaming setup. Config#:1403651 Specifications for a Harker, Ive played around with some Desktop rigs but not so sure which direction to go with those, specially when it comes to Liquid Cooling. Chassis Chassis Model: Digital Storm Harker 17.3 Inch Laptop (Model: S:9778) Display: NVIDIA G-Sync - 17.3 Inch (1920 x 1080) IPS LED-Backlit Display (Anti-glare) Screen Calibration: - No Thanks Core Components Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Thermal Compound: Premium CPU and GPU Thermal Compound (Reduces Thermal & Laptop Noise) Memory: 16GB DDR4 2133MHz Storage / Connectivity mSATA SSD: - No Thanks Storage Drive 1: M.2 SSD - 256GB Samsung 950 PRO (NVM Express) Storage Drive 2: - No Thanks Optical Drive: - No Thanks Wireless Card: Killer Dual Band Wireless-AC 1535 + Bluetooth (M.2 Socket) Graphics / Multimedia Graphics Card(s): NVIDIA GeForce GTX 970M 6GB (NVIDIA G-Sync + NVIDIA Battery Boost) Software Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office Suite: - No Thanks Accessories / Goodies Cooling Pad: ZALMAN High Performance Notebook Cooler NC11 Extra Charger: - No Thanks Extra Battery: - No Thanks Carry Bag: - No Thanks Audio: - No Thanks Mouse: - No Thanks T-Shirt: - No Thanks Customer Care Priority Build: Please Prioritize: Ship Within Four Business Days After Order Is Successfully Processed Warranty Plan: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
Quote Reply Posted: 23 Apr 2016 at 9:05am |
Hi DarkSideRider21..... If you're staying away from a desktop gaming rig to avoid going with liquid cooling, you don't have to. The air coolers offered will cool the cpu just fine. The Noctua air cooler is the best, is very quiet, cools great and lasts and lasts.
For the money, a desktop will give you much better performance than a laptop. Your laptop build vs a Vanquish level 3 with its gtx 970 for example will save you a $1000 and give you a good 50% better fps in gaming with a 1080p monitor over the 970M mobile card. You could go custom and start with the Apollo and select a better power supply, any storage option you want and have a pc case that is easy to work on or add to down the road. If you want to keep mobility then the laptop would be the way to go. |
Quote Reply Posted: 23 Apr 2016 at 9:20am |
Here's a comparable custom Apollo config to the Vanquish with a better power supply, motherboard, cpu cooler, HDD, etc an still under budget.
Config # 1404280 Cost $ 2095 Chassis Model: Special Deal Hot Seller - Digital Storm Apollo (White) Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z170 PRO GAMING (Intel Z170 Chipset) (Up to 5x PCI-E Devices) System Memory: 16GB DDR4 2666MHz Digital Storm Certified Performance Series Power Supply: 750W EVGA SuperNOVA Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) (Internal) Storage Set 1: 1x SSD (250GB Samsung 850 EVO) Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: AIR: Stage 2: Noctua NH-D15 (Extreme Performance) HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Blue) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard) Graphics Boost: - No Thanks, Please do not overclock my video card(s) OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) Edited by bprat22 - 23 Apr 2016 at 9:22am |
DarkSideRider21
Quote Reply Posted: 23 Apr 2016 at 12:43pm |
awesome, thanks so much for the advice, the more i think about this I keep leaning towards a desktop since it would just be better and last longer, plus it will be easy to upgrade. Would a Hydrolux Cooling with Flexible Tubings provide me and advantage or would it just be good to have for future upgrades? im not fully against cooling BUT im just paranoid of having fluid running through a PC, but if its a better option and would allow for better upgrades in the future, id be willing to do the hydrolux with the Flex tubes (mainly because if im going to do it, i might as well enjoy the look too :). Again thanks so much for the config and advice
db188
Quote Reply Posted: 23 Apr 2016 at 2:41pm |
i wouldn't spring for a custom water loop unless i was cooling multiple components (i.e. cpu+graphics cards+chipset) or intending to push my cpu oc really high (and then again you can just get an AIO with a bigger radiator). custom water loops are really just an "enthusiast sport" to coin a phrase. unless you're really into them stick with an AIO water cooler or even an air cooler. a top of the line air cooler will support a moderate cpu oc. an AIO water cooler with a 240mm rad will do the same, perhaps a little higher oc. an AIO with a 360mm rad will handle high oc'ing.
an air cooler will last you forever. downside to them are the size and weight. it makes them difficult to work around and stress on the mobo (especially during shipping). an AIO water cooler is low profile around the cpu socket, so it's easy to get to RAM sticks for troubleshooting, upgrading. etc. no stress on the mobo. looks cleaner, imo. no maintenance required (as opposed to a custom water loop). the only real downside to them is they won't last forever-typically around 3-5 years before the pump goes out, ymmv. |
Aventum 3
DarkSideRider21
Quote Reply Posted: 24 Apr 2016 at 3:38pm |
New Setup: 1404941 let me know what you think
Chassis Chassis Model: Digital Storm Apollo (White) Core Components Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z170 PRO GAMING (Intel Z170 Chipset) (Up to 5x PCI-E Devices) System Memory: 16GB DDR4 2666MHz Digital Storm Certified Performance Series Power Supply: 850W EVGA SuperNOVA Storage / Connectivity Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) (Internal) Storage Set 1: 1x SSD (256GB Samsung 850 PRO) Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics / Multimedia Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (VR Ready) Sound Card: Integrated Motherboard Audio Digital Storm Engineering Extreme Cooling: H20: Stage 2: Corsair H115i - 280mm Radiator Liquid CPU Cooler HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Corsair LED Airflow Performance Edition (Green) (Up to 6 Fans) Internal Lighting: Internal Chassis Lighting System (Green) Digital Storm TwisterBoost Technology Boost Processor: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard) Software Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Accessories / Goodies Customer Care Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 4 Year Limited Warranty (4 Year Labor & 2 Year Part Replacement) |
