hello every body, help mePost Date: 2018-05-01 |
Author | ||
mariasmile509
Newbie Joined: 01 May 2018 Online Status: Offline Posts: 1 |
Topic: hello every body, help me Posted: 01 May 2018 at 11:58pm |
Quote Reply Posted: 02 May 2018 at 2:08am | |
Welcome to the forums.
Here’s a build that has the most recommended parts and pretty close to what I’m looking to get in the near future. You said beyond 1080p for a monitor, so I put in the gtx 1080ti in case you go 1440p at 144hz or 4 k. The cpu cooler is very good. You could change to the stage 1 air cooler since we not overclocking, so up to you. The Air cooler is most reliable with no pump, etc to fail but the Corsair gives you headroom in case you overclock. Configuration Code: 1918117 Total Price with Instant Savings: $3,737.00 Direct Load URL: https://www.digitalstorm.com/configurator.asp?id=1918117 Specifications: Chassis Model: Digital Storm Lumos Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7-8700K (6-Core) 3.70GHz Motherboard: MSI Z370 GAMING PRO CARBON AC (Wi-Fi) (Intel Z370 Chipset) (Up to 3x PCI-E Devices) <br><strong></strong> System Memory: 16GB DDR4 3000MHz Digital Storm Performance Series <br><strong></strong> Power Supply: 750W Corsair RM750x (Fully Modular) <br><strong></strong> Expansion Bay: - No Thanks Optical Drive: - No Thanks Storage Set 1: 1x SSD M.2 (512GB Samsung 960 PRO) (NVM Express) (Extreme Performance) <br><strong></strong> Storage Set 2: 1x SSD (1TB Samsung 860 EVO) <br><strong></strong> Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce GTX 1080 Ti 11GB (Performance Edition) (VR Ready) <br><strong></strong> Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H100i GTX - 240mm Liquid CPU Cooler (Fully Sealed + No Maintenance) <br><strong></strong> HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Corsair ML PRO Series (High Static Pressure) (Magnetic Levitation) <br><strong></strong> Internal Lighting: Remote Controlled Advanced LED Lighting System (Multiple RGB Color Modes) <br><strong></strong> Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: Option Not Available Boost Processor: Stock Factory Turbo Boost Advanced Automatic Overclocking Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: USB Drive - Windows 10 Installation (Format and Clean Install) Virus Protection: Windows Defender Antivirus (Built-in to Windows 10) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 15-20 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) Hope this helps. |
Quote Reply Posted: 02 May 2018 at 2:12am | |
Just to add, I would up the warranty to 4 years labor and 2 years parts. The first year goes by real quick and dealing with DS as one stop troubleshooting is the way to go.
hoserator
Quote Reply Posted: 02 May 2018 at 2:58am | |
Welcome to DS. That is one very nice system bprat22 configured for you. I would only change the OS to W10 Pro. It gives you some more control.
The sweet spot right now IMO on monitors are the 1440p/144hz and bprat22 has you more than covered with that 1080 Ti. Enjoy. |
Quote Reply Posted: 02 May 2018 at 4:21am | |
Hey hose.....What monitor are you using ? I know you mentioned it before. I might go 27” 1440p at 144hz. The OP might also want a suggestion. Thanks. |
hoserator
Quote Reply Posted: 02 May 2018 at 12:11pm | |
Hi bprat22, you know there are many monitors out there.
I am using an Asus ROG Swift PG279Q (can be oc to 165Hz but I keep it at 144). It is an ips panel. Also have used a PG278QR which is a tn panel and also very good (also Asus).I have read here some are using an Acer Predator XB271HU and love it. Note that these are G-Sync and not FreeSync (AMD). |
Quote Reply Posted: 02 May 2018 at 3:36pm | |
Thanks for the monitor info. Get ready to trade in my good old Dell 24” for a new experience. |
hoserator
Quote Reply Posted: 03 May 2018 at 3:51am | |
Knowing you, I am sure you will check the reviews and wow us with your find. There are some interesting panels out there. I stopped checking for 4K. I love this one and don't think higher resolution is the answer for aging Mark I eyeballs.
Quote Reply Posted: 03 May 2018 at 2:13pm | |
Yeah , 1440p is fine for me. Not going 4K.
Tidgxor
Quote Reply Posted: 03 May 2018 at 2:54pm | |
Some of us are still happy at 1080p. |
Quote Reply Posted: 03 May 2018 at 3:13pm | |
I hear ya. 1080p is still good here too, but gotta try different. Why ? Just because. |
Tidgxor
Quote Reply Posted: 03 May 2018 at 3:20pm | |
Totally agree.
Might make the jump myself later this year, depending on finances and the phases of the moon. |
Cretae
Quote Reply Posted: 04 May 2018 at 5:44am | |
I hear ya. 1080p is still good here too, but gotta try different. Why ? Just because. [/QUOTE]
Ooh, ooh, me, too! |
