Help with Configuration upgradePost Date: 2015-10-21 |
gonarip
Newbie Joined: 06 May 2011 Online Status: Offline Posts: 10 |
Topic: Help with Configuration upgrade Posted: 21 Oct 2015 at 2:10pm |
Hi. This is my current computer and I would like to upgrade it to a standard 2015 gaming rig.I did upgrade my video card to Nvidia gtx 980 Ti and 16 gig of ram. I need advice on a Motherboard, CPU, Cooling system and anything else if needed.I mostly use it for gaming and I want to be able to run any games on Max settings. Thank you.
Open Budget but I don't need to ovespend on uneeded components. . System Configuration: Chassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) Motherboard: ASUS P8P67 Deluxe (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 320 Series SSDSA2CW120G3K5) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card(s): 2x SLI Dual (NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: Noctua NH-U12P SE Dual 120mm Fans High Performance Cooler H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks CPU Boost: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro or Deluxe Series Motherboard) Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: Memory Fan Kit Only (Does not include memory overclocking service) OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) |
Quote Reply Posted: 21 Oct 2015 at 2:30pm |
Hi gonarip... To update ahead a few generations you could get the Asus Z170 Deluxe with the i7-6700k and 16gb DDR4 2666mhz ram.
For cooling, stick with Noctua and grab their new Noctua D15. HafX with Noctua was always my favorite combo here at DS until they retired the case. Can't do better. Have fun. |
db188
Quote Reply Posted: 21 Oct 2015 at 3:34pm |
there's really no need as long everything is running fine. upgrading your graphics was probably the only real difference maker for gaming. yes, you get about 20% IPC improvement with the new quad core over that Sandy Bridge, but the Sandy won't be holding back your graphics, so who cares? besides, if you move to the new platform, you'll need: a new mobo and new DDR 4 system memory (which will make your ram capacity upgrade moot). if you're current cpu is cooled well enough by its current cooler, then no need to upgrade.
are you looking to upgrade just to have the new shiny? or are you thinking you're lacking performance with your current system? are components failing? if you really want a substantial/noticeable upgrade with your current system, buy yourself a new monitor, preferably a 1440p IPS like this: Acer XB270HU bprz Black 27'' 144Hz WQHD G-SYNC Widescreen LED Backlight LCD Monitor IPS 350Edited by db188 - 21 Oct 2015 at 3:39pm |
Aventum 3
