Laptop battery seems to be deadPost Date: 2015-01-03 |
JerDev
Newbie Joined: 19 Jul 2013 Online Status: Offline Posts: 30 |
Topic: Laptop battery seems to be dead Posted: 03 Jan 2015 at 6:27pm |
Laptop only works when plugged in. I bought the laptop August of 2013. When on my desk, the laptop would always be plugged in. In fact it was almost always plugged in the majority of the time. O:nly a few times had it be run on the battery.
What could be the issue? Am I able to get a replacement battery? Would my warranty cover it? I must say that I use two chargers, one given by digital storm, and another bought for $80 online. Same voltage, same everything. So that cant be the reason. Original: http://i.imgur.com/oiuakPA.jpg Bought: http://i.imgur.com/kZubS5C.jpg Screenshot: http://i.imgur.com/Fb2gu18.png Laptop = Veloce Digital Storm Order = #28686 Edited by JerDev - 03 Jan 2015 at 6:37pm |
Quote Reply Posted: 03 Jan 2015 at 6:38pm |
Laptop batteries do die and I doubt warranty would cover it. DS could sell you one or tell you where to get one.
Try removing the battery, unplugging the laptop for a few minutes. Then reinstall the battery and check it or see if it charges after hooking to AC. Sometimes the laptop needs all power removed to reset . |
