Need help on my Digital Storm Custome PC
Post Date: 2012-11-15
adam_my View Drop Down
  Quote adam_my Quote  Post ReplyReply bullet Topic: Need help on my Digital Storm Custome PC
    Posted: 15 Nov 2012 at 1:34am
Hi, I'm Adam from Malaysia. I really need some advise and info on choosing the right digital storm pc for my daily working routine. I tried to customize using the 'digitalstormonline' web and here are two customize spec that I like and would like some help,review or advice on it.
A-Digital Storm Syndicate
-Chassis Model: Special Deal Hot Seller - Black OPS Syndicate
-Processor: 2x Dual (Intel Xeon E5-2687W 3.10GHz (20MB Cache) (Eight-Core CPU) (16 CPU Cores Total)
-Motherboard: Intel Workstation Board W2600CR
-System Memory: 64GB DDR3 1333MHz (ECC Registered) Digital Storm Certified Performance Series (8GBx8 Config)
-Power Supply: 1500W Silverstone (Dual/Triple/Quad SLI Compatible) (Recommended)
-Expansion Bay: Internal Digital Media Card Reader (Black)
-Hard Drive Set 1: Operating System: 2x (240GB Solid State (By: Intel) (Model: 520 Series)
Set 1 Raid Options: Configure HDD Set 1 to a Raid 0 Config - Stripe Performance (Requires Two HDDs)
-Hard Drive Set 2: Multimedia\Data: 2x (240GB Solid State (By: Intel) (Model: 520 Series)
-Hard Drive Set 3: Backup\Misc.: 1x (3TB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (SATA 6Gbps)
-Optical Drive 1: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST)
-Optical Drive 2: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R)
-Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections)
-Video Card(s): 3x SLI Triple (NVIDIA GeForce GTX 680 4GB (Includes PhysX)
-Add-on Card: 1x NVIDIA Tesla C2075 Computing Processor (6GB of Memory)
-Sound Card: Creative Labs Recon3D Fatal1ty Champion 5.1 (Includes Front I/O) (PCI-Express Slot Based)
-Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Quad SLI/CrossFire Video Cards & Chipset
-H20 Tube Color: Red Tubing with High-Performance Fluid (UV Lighting Reactive)
-Chassis Airflow: Upgrade Chassis With Zalman Performance Fans (Up to 6 Fans)
-Internal Lighting: Internal Chassis Lighting System (Red)
-Enhancements: Strike-X AeroCool Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade)
-Chassis Mods: HailStorm & 950Si: Processor & Video Card Area: Drill and Mount Two Side Window 120mm Fan Blow-Holes
-Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material)
-OS Boost: Yes, Disable and tweak all of the non-crucial services on the operating system
-Windows OS: Microsoft Windows 7 Ultimate (64-Bit Edition)
-Recovery Tools: Advanced Recovery Kit (40GB Hard Drive Partition of Image With OS & Drivers)
-Display: NVIDIA 3D Vision Surround Setup (3x Triple Asus 3D Panels 23 inch VG236H (Includes 3D Glasses)
B-Digital Storm Aventum
-Chassis Model: Special Deal Hot Seller - Black OPS Aventum
-Processor: Intel Core i7 Extreme Edition 3970X 3.5GHz (Six-Core) (Extreme Performance)
-Motherboard: ASUS Rampage IV Extreme X79 (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s)
-System Memory: 64GB DDR3 1600MHz Corsair Dominator DHX (High-Performance)
-Hard Drive Set 1: Operating System: 2x (240GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps)
-Hard Drive Set 2: Multimedia\Data: 2x (240GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps)
-Optical Drive 1: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Slim Slot Loading Edition)
-Optical Drive 2: - Not Available
-Add-on Card: USB 3.0 4-Port PCI Express Card
-Extreme Cooling: Digital Storm Aventum Cryo-TEC System for CPU and Liquid Cooling for Video Cards + Chipset
-Chassis Airflow: Digital Storm Aventum Automatic Response to Excess-Heat System (ARES)
-Internal Lighting: Digital Storm Aventum RGB LED Lighting System
-Enhancements: Digital Storm Aventum Integrated Side Panel Display Module
-CPU Boost: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro/Deluxe/Sabertooth Motherboard)
-Graphics Boost: Yes, Overclock the video card(s) as much as possible with complete stability
-Memory Boost: Memory Fan Kit Only (Does not include memory overclocking service)
Expectations/Usage/Special Needs:
- looking for the best spec which support a triple monitor setup or six monitor setup such as Samsung's MD230X6 six-screen Eyefinity. The reason for that is because i need each monitor to display different program or application simultaneously, for example :
six monitor setup:-
monitor 1(top) - connectivity monitoring like network,data transfer,pc temp,etc.
monitor 2(top) - stock/forex exchange,etc
monitor 3(top) - news/bloomberg,etc
monitor 4(below) - viewing CCTV
monitor 5(below) - photo/video editing,internet browsing,etc.
monitor 6(below) - Playstation 3 or Xbox 360 gaming display
or
monitor 4,5,6(below) - pc gaming.
- extream pc gaming with highest setting on all games
- as being told in the above example of each monitor usage.
- willing to discuss with Digital Storm Personnel on this matter.
My Question:
1- Which setup or configuration that can do all the things I stated above, is it the Digital Storm Syndicate or Digital Storm Aventum ?
or do I need other special customization ?
2- Which of the two setup that more stable/solid build ? in term of stability, cooling system, multitasking, heavy loading/processing data, less noise, easy to maintain or upgradeable ?
3- Does Digital Storm willing to ship the goods to Malaysia if I purchase either one of the system ?
(i'm willing to bare all the shipping cost)
4- How about the warranty due to I'm not a US citizen and I'm in Malaysia ?
Please do help me on this matter as i'm not an expert on hardware tech and I do apologies on my english.
Sorry if I post on the wrong section.
Thank you.
Edited by adam_my - 15 Nov 2012 at 1:35am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Nov 2012 at 6:17am
Hi adam_my.    Welcome to the forums.
Those are two great rigs.  I don't know the workstation Xeon cpu's but my vote would be the Aventum.  It's DS's flagship rig with the latest and greatest.
There are a couple of changes I would make.  The Noise Suppresion package, Chassis Mod  drill two fan holes and the Memory Fan Kit I don't believe apply to the Aventum.
I would also drop the Cryo-TEC cpu cooling in favor of the Aventum Liquid cooling for cpu, cards and chipset.  This being sent overseas would make servicing the Cryo-TEC, if necessary, a challenge.  Liquid cooling is more servicable and parts more readily available.  Not that it will need service, but yeah never know.  Shipping back to DS could be very expensive.
The Aventum is a system best setup with DS on the phone.
Good Luck.
