Newcomer needs help choosingPost Date: 2016-11-24 |
Elkabong109
Newbie Joined: 24 Nov 2016 Online Status: Offline Posts: 3 |
Topic: Newcomer needs help choosing Posted: 24 Nov 2016 at 11:12am |
I'm sort of torn between a Vanquish 5 Level 3 and an Apollo Level 1. I was shooting to keep the cost around $1500, but for another $300 I'm tempted to purchase the Apollo. I like the Vanquish, but it seems that the Apollo is definitely a step above and something I can upgrade for the forseeable future. Any thoughts. Thank!
And Happy Thanksgiving! |
Wipeout
Newbie Joined: 06 Sep 2011 Online Status: Offline Posts: 41 |
Quote Reply Posted: 25 Nov 2016 at 7:19pm |
interested in the replies to this :)
Quote Reply Posted: 26 Nov 2016 at 2:56am |
As -is, without making any changes, the Vanquish has the stronger video card, very important, and the Apollo has an overclockable CPU and more storage.
Best bang for your buck is the Vanquish. The Apollo, being fully customizable, gives you the option to select better power supply, motherboard, and most other components. The Vanquish is a few hundred dollars cheaper for similar performance because it's not as customizable and DS can prebuilt them to a degree with parts that can get deals on from the manufacturers. They are both equally upgradable. Unless you're plan on spending more to select parts with better warranty, more efficiency, etc, get the Vanquish. They are good deals for tight budgets. Hope this helps. |
Elkabong109
Quote Reply Posted: 26 Nov 2016 at 3:22pm |
Actually that helps a lot. Taking the Apollo was pretty much a stretch in terms of what I'd like to spend. I just like the fact that it has liquid cooling, and all of my rigs in the past were fan cooled, to various degrees of success, lol. Though I couldn't spend much more than the lowest tier Apollo, it just seemed a better buy, but I completely get what you say about the Vanquish as a better value for the buck. Thanks!
Quote Reply Posted: 26 Nov 2016 at 3:39pm |
My pleasure..
Actually, in my opinion, one of the advantages of the Vanquish level 3 is its air cooler. While it's not a top tier air cooler, it does the job without the worries of pump failure, etc. with the liquid cooling. The gtx 1070 in the Vanquish is a much stronger card than the gtx 1060 in the Apollo level 1, by about 30% or better. Here's a link comparing them.... http://www.anandtech.com/bench/product/1771?vs=1731 |
Elkabong109
Quote Reply Posted: 27 Nov 2016 at 8:47am |
Would you recommend upgrading the fan? They offer the Corsair airflow for another $99. Kind of expensive, but cooling has always been an issue for me, particularly in the summer months here in Texas lol.
Quote Reply Posted: 27 Nov 2016 at 8:58am |
Nope. Use the $99 for a couple of games.
For your setup the stock fans are very good. |
Meller
Quote Reply Posted: 27 Nov 2016 at 1:48pm |
Bprat is right, in my opinion on the fans. Stock fans will be fine when they don't really need much static pressure.
As time goes on, and you save up, you can buy some nice custom fans from companies like Corsair to help aesthetics and performance, but stock fans that are just pushing into open spaces will 100% fine. Corsair has some really nice ML fans, now... their HD120 and SP120 RGB fans look amazing. All things you don't really need at all, but will be nice little upgrades later down the road to reduce noise and add some extra "flair" to your build. |
Custom PC
