OC question
Post Date: 2012-01-21
hotshot146 View Drop Down
  Quote hotshot146 Quote  Post ReplyReply bullet Topic: OC question
    Posted: 21 Jan 2012 at 5:35pm
I have a friend that has the 3960x and got it overclocked can not remember if it was 5.3 or 5.5 on IC. I wanted to know what is the highest overclock with the new cpus have you guys got to?
The settings he used
BLCK 130
CPU strap 125
Muilt. set to 43
vcore 1.37
Edited by hotshot146 - 21 Jan 2012 at 5:36pm
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 21 Jan 2012 at 6:43pm
I haven't had chance to play around with the new line of CPUs, likely won't unless a friend gets one Oops
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Jan 2012 at 9:35pm
Thats a oc of 5.5Ghz, there is no way that oc is stable or correct with that vcore or the vcore is not reported correctly.
We are not benchmarking here, so its not about how high our ocs go, we are more about how high can I go and have my cpu live at least 5 years if not longer.
with a 5.5Ghz proper stable oc, you looking at vcore of 1.5 or higher, at that vcore under 24/7 load your cpu will be fried in a year.
Edited by DST4ME - 21 Jan 2012 at 9:36pm
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 28 Jan 2012 at 9:31pm
Got 4.7GHz on a 3930K @ 1.35v, so 5.5GHz is not totally out of reach in the mid 1.45v range (depends on the chip obviously).
I plan to run a 3960X at as high as it will go on water, so we'll see how long it lasts DST4ME. :P
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Jan 2012 at 10:11pm
You but with what vcore? if you are talking above 1.5 I like to enter a bet for one year or less
beamlester View Drop Down
  Quote beamlester Quote  Post ReplyReply bullet Posted: 30 Jan 2012 at 2:37am
i have plan to run above 1.8x have u any information about thisDisappointed
Pakistani, Indian & Western Wear Dresses at thetrendystyle.com | thetrendystyle.com/collection_2012.htm | thetrendystyle.com/collection_2012/sarees_collection_2012/sc_2012_main.htm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 01 Feb 2012 at 12:31am
at 1.7 it will fry right away, I don't see how you get to 1.8 or higher.
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 01 Feb 2012 at 10:17am
1.8+ would be easy.
If you are using a Pentium from 13 years ago.
Hahaha
