Water Cooling Replacememt
Post Date: 2018-01-10
Ravenwjf View Drop Down
  Quote Ravenwjf Quote  Post ReplyReply bullet Topic: Water Cooling Replacememt
    Posted: 10 Jan 2018 at 4:54pm
Hey,
So I have an Aventum 3 with a water cooler and I have been using the EK-Ekoolant EVO Blood Red. After a cracked water block I had to replace and doing some minor adjustments to the tubing and connections I have about a quarter of a bottle left. I have been trying to re-order/replace it and I can't find it anywhere. One website said it was at end of life, and all the others are out of stock. Does anyone know where you can get more or a suitable replacement for the water cooling? Thanks for any inputs!!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Jan 2018 at 5:24pm
If you can't find the exact one you will need to flush clean and replace the fluid.
Mayhem has good fluid
Edited by DST4ME - 10 Jan 2018 at 5:25pm
  Quote Ravenwjf Quote  Post ReplyReply bullet Posted: 10 Jan 2018 at 5:35pm
Ok, cool, thanks!! I knew I would have to flush if I changed, I just wasn't sure on a good replacement fluid.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Jan 2018 at 5:44pm
Flush and thoroughly cleaned, don't want even a drop of old fluid anywhere in the loop.
Rinse with distilled water or mayhem has things for that also i think.
Edited by DST4ME - 10 Jan 2018 at 5:44pm
