What case best replaces Hailstorm and?Post Date: 2016-11-22 |
neilkaz
Groupie Joined: 02 Mar 2010 Online Status: Offline Posts: 156 |
Topic: What case best replaces Hailstorm and? Posted: 22 Nov 2016 at 1:01pm |
I haven't purchased a computer in several years and want to take advantage of DS's Black Friday sale.
Here's my intended system and yes, I do need the best number crunching possible and, yes, one high end video card is adequate for me. Configuration Code: 1528818 Total Price with Instant Savings: $5,352 Load Configuration URL: https://www.digitalstorm.com/configurator.asp?id=1528818 If you have any questions or have any questions or comments regarding this configuration, please send us a message: https://www.digitalstorm.com/request-help.asp Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Velox <br><strong></strong> Exterior Finish: - Standard Factory Finish Trim Accents: - Not Available Processor: Intel Core i7 Extreme Edition 6950X 3.0GHz (10-Core) (Extreme Performance) Motherboard: ASUS X99-DELUXE II (Intel X99 Chipset) (Up to 4x PCI-E Devices) System Memory: 32GB DDR4 2666MHz Digital Storm Certified Performance Series Power Supply: 1000W Corsair HX1000i (Digitally Controlled Power) Expansion Bay: Option Not Available Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x) (Internal) Storage Set 1: 1x SSD M.2 (512GB Samsung 950 PRO) (NVM Express) (Extreme Performance) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce GTX 1070 8GB (NVIDIA Founders Edition) (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: HydroLux PRO: Exotic Custom Cooling System (CPU Only) HydroLux Tubing Style: Flexible Tubing (Requires HydroLux Liquid Cooling System) HydroLux Fluid Color: Red Fluid (Requires HydroLux Liquid Cooling System) Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software) Airflow Control: Digital Storm Thermal Management Control Board & Software Chassis Mods: Fan Blow-Holes: CPU & Graphics Card Area: Laser Cut and Mount (2x) Side Window 140mm Fans Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard) <br><strong></strong> Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 15-20 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) Originally I spec'd this system with the Hailstorm case but that doesn't qualify for free shipping. Is the Velox case the best replacement that can be shipped free. It look like it can also take some side hole for extra fans that I'd like for even more cooling. One question, what O/C is DS typically getting with these new 10 core chips? Thx for any advice ... neilkaz ... |
HAF932
i7-980X at 4.34 Ghz HT 24/7 GTX 275 6 MB STT DDR3 at 1628 MHz Stage 4 cooling |
Quote Reply Posted: 22 Nov 2016 at 5:04pm |
Probably the Velox, but the Apollo's Corsair 760 t would also work just fine for your setup.
Not sure about the oc, I'd ask DS. On water, the 4.4 should be typical. |
neilkaz
Quote Reply Posted: 29 Nov 2016 at 11:04am |
Thx for the advice and thx to Brian in chat.
I purchased yesterday and plowed the Cyber Monday savings back into some even higher end components. I didn't want to feel the need to buy a new computer for a couple of years. Chassis Model: Special Deal Hot Seller - Digital Storm Velox Exterior Finish: - Standard Factory Finish Trim Accents: - Not Available Processor: Intel Core i7 Extreme Edition 6950X 3.0GHz (10-Core) (Extreme Performance) Motherboard: ASUS X99-DELUXE II (Intel X99 Chipset) (Up to 4x PCI-E Devices) System Memory: 32GB DDR4 3200MHz Corsair Dominator Platinum DHX (Extreme-Performance) Power Supply: 1000W Corsair HX1000i (Digitally Controlled Power) Expansion Bay: Option Not Available Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x) (Internal) Storage Set 1: 1x SSD M.2 (512GB Samsung 950 PRO) (NVM Express) (Extreme Performance) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce GTX 1080 8GB (NVIDIA Founders Edition) (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: HydroLux PRO: Exotic Custom Cooling System (CPU Only) HydroLux Tubing Style: Flexible Tubing (Requires HydroLux Liquid Cooling System) HydroLux Fluid Color: Red Fluid (Requires HydroLux Liquid Cooling System) Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Corsair Airflow Performance Edition Fans Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software) Airflow Control: Digital Storm Thermal Management Control Board & Software Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard) Graphics Boost: - No Thanks, Please do not overclock my video card(s) OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) |
HAF932
Quote Reply Posted: 29 Nov 2016 at 11:07am |
Nice rig.
Pretty soon you'll have to update your sig. |
neilkaz
Quote Reply Posted: 29 Nov 2016 at 12:45pm |
That I will once I know what the O/C is. This is my 4th DS computer and I expect that over subsequent years I'll order more.
HAF932
