AudioPost Date: 2015-08-09 |
LeeEricson
Newbie Joined: 09 Aug 2015 Online Status: Offline Posts: 7 |
Topic: Audio Posted: 09 Aug 2015 at 5:04pm |
I recently purchased a VANQUISH 3 level 2 computer. Config ID DOS-781338. Was wondering if there is any room to add a sound card some day.
- NVIDIA GTX 960 4GB - Intel Core i5 4590 CPU - 8GB 1600MHz Memory - 120GB Samsung EVO SSD - 1TB 7200RPM HDD - Upgraded CPU Air Cooling - H81 Motherboard - 600W Power Supply - DVD-R/RW/CD-R/RW |
Quote Reply Posted: 09 Aug 2015 at 5:18pm |
Hi LeeEricson.... Without knowing the exact motherboard I can't say 100%, but chances are , below the gtx 960, is an empty PciEx1 slot an audio card will slide into. Just make sure the audio card has the Pciex1 interface. Most do, but older ones might have a Pci connector.
Hope this helps and good luck. |
Quote Reply Posted: 09 Aug 2015 at 5:23pm |
There I most likely room. The graphics card only takes up two slots and the motherboard will have at least 3, probably with a PCI-e x1 slot that can accept a sound card.
Why do you want a sound card? The only good reason to get one is if you have or are getting high quality headphones with a 1/4" jack. Otherwise, you would be better off spending that money on higher quality speakers/amps and use the sound processing on the motherboard. Edited by - 09 Aug 2015 at 5:23pm |
LeeEricson
Quote Reply Posted: 09 Aug 2015 at 5:47pm |
I see it its labeled PCIEX1_2
I was not aware the sound processor was that good on the mother board. I just have a cheep pair of speakers on it now. Any suggestions on the speakers. Seems to be a lot out there. Thanks for the info |
ArkansasWoman777
Quote Reply Posted: 09 Aug 2015 at 6:21pm |
i recommend the Klipsch Pro Medias
Quote Reply Posted: 09 Aug 2015 at 8:17pm |
A few dB of signal gains with as little noise there is won't gain you much. A better speaker response will get you much better sound from the system...especially on the low end with these kinds of setups.
