Need Help with setup.
Post Date: 2015-09-30
chaby View Drop Down
  Quote chaby Quote  Post ReplyReply bullet Topic: Need Help with setup.
    Posted: 30 Sep 2015 at 6:16pm
         Budget $ 3k or so.
   General Gaming.
   Didn't place order yet.
   Digital Storm Apollo
   Core i7 6700K 4.0Ghz
   MB:GIGABYTE Z170X-Gaming 3
   SYSTEM Memory 16GB DDR4 280Mhz DS Certified Performance Series
   Power Supply:850W EVGA SUPER NOVA
   Optical Drive: DVD Driver-CD Driver
   Storage 1: 1xSSD( 256GB SAMSUNG 850 PRO
   Storage 2: 1TB Western Digital-Black Edition
   INTERNET: High Speed Network Port
   Graphics Card: NVIDIA GeForce GTX 980 Ti 6GB (ASUS Strix Edition)
   Extreme Cooling: H20: Stage 2: Corsair H110i GT
   Windows OC: Microsoft Windows 8.1 Pro
   Display: Asus 4K Ultra HD 28 inch PB287Q Series......
   Hi guys. What do you think? I'm real noob.Any help would be greatly appreciated.Tnanks in advance. Confused
   What Windows to get?
   What about my choice of the monitor ?
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 30 Sep 2015 at 6:32pm
Looks good. You may need to turn some of your game settings down from the maximum when playing at 4K, but it shouldn't be bad. You're component selection will let you add a second Strix card later if you want to have maximum settings in game.
If you can spare an extra $200, you can opt for a single 1TB Samsung Evo drive in place of the 2 drives you have selected. I personally prefer to have a single storage volume and SSDs are awesome to work with, but some people are fine with multiple drives.
You'll be fine with Windows 10 Home. It supports DirectX 12 and I'm guessing you're not going to be using the features in W10 Pro, which you can always upgrade to later on if you need to.
Edit: Oh, I'd spend the extra $20 to the extra overclock to get the core frequencies up to 4.5 or 4.6 GHz (you'd have to be rather lucky to get 4.7 or 4.8 GHz).
Edited by  - 30 Sep 2015 at 6:34pm
db188 View Drop Down
  Quote db188 Quote  Post ReplyReply bullet Posted: 30 Sep 2015 at 6:33pm
you'll see frames drop into the low 20's at times (depending on settings) on some games with a single 980ti.
  Quote chaby Quote  Post ReplyReply bullet Posted: 30 Sep 2015 at 7:04pm
High guys. Thank you for fast response. NO NAME ? I took my setup from one of your posts.So thanks for that.For the last few days, i was all over this great forum, trying to get as match info i can get. My head is spinning.Like i said, real amateur
here, so i had some noob questions if i may.With this monitor, can i play with lower
then 4k resolutions, or its gonna be some sort of problem?
  Quote db188 Quote  Post ReplyReply bullet Posted: 30 Sep 2015 at 7:20pm
depends on the 4k monitor's scaler tech.  i've heard of blurry image quality when downsampling to lower resolutions with some monitors.  best to check with the vendor on that question before purchase.  as a general rule i advise always using "native" resolutions.
  Quote chaby Quote  Post ReplyReply bullet Posted: 30 Sep 2015 at 7:29pm
Thanks for your help db188. I will go, and clear this out.
  Quote db188 Quote  Post ReplyReply bullet Posted: 30 Sep 2015 at 7:30pm
here's an article i found on the monitor tested in games that should provide helpful info on the subject: http://www.eurogamer.net/articles/digitalfoundry-2014-asus-pb287q-review
in summation, it scales pretty well to 1080p gaming with some image quality tradeoff.
  Quote chaby Quote  Post ReplyReply bullet Posted: 30 Sep 2015 at 8:15pm
Yeaa.. Thanks db188. i desided to steer away from that monitor.I'll go with Asus 24 VG248QE Series monitor. Is it any good? The reason i just don't have horses in my setup to really use 4k capabilities. I'll spend extra for bigger SSD drive,that i was advice
by DS Veteran. Should i get this VG248QE monitor? Or should i get something better outside the shop? I'm really was looking for 27' inch monitor. Any suggestion
guys? Thank you in advance.
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 30 Sep 2015 at 8:25pm
I7 13700KF 5.4hz
ASUS Prime z790 MoBo
ASUS Dual 4070
32g ram@5200
850 Gold PSU
1TB SSD 2TB SSD
27" ASUS Monitor 144hz
Razer Ornata Chroma Keyboard
Razer Basilisk V2 Mouse
Nari Ultimate Headset
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 30 Sep 2015 at 9:01pm
Yes, I've played some games at 1080p on a UHD TV and did not experience any issues. You can also try out for yourself and determine if you prefer high details at lower resolution, or higher resolution but lower details.
And I was just stating my preferences in regards to the drive. You should figure that each modern AAA game (the big budget games that cost $60 new) will take up ~50GB each of storage (very rough approximation). If you bounce between a lot of games, figure you will need more storage, but if you only play a few at any given time, you can remove games you're not using and not need as much storage to begin with. Media files, especially video, are also other considerations to make for storage needs. But, in my opinion, the cost disparity between HDDs and SSDs are getting close enough where the performance advantage makes it worth the cost...but then again, I don't use that much storage...only 192GB used on my 512GB SSD (only storage) since fresh operating system install a year ago.
  Quote db188 Quote  Post ReplyReply bullet Posted: 30 Sep 2015 at 10:46pm
it's an okay 1080p monitor.  here's my advice: you have 3K-ish budget.  get yourself a Vanquish L4 (~$1600) and you'll have enough left over to get yourself a really nice 27" IPS gaming monitor like the ($800) Acer Predator XB270HU bprz 1440p G-Sync 144Hz that your system can handle well.  trust me, you'll enjoy the image quality and performance combination with this setup over trying to get fancy with one of the more higher budget custom DS jobs.
  Quote chaby Quote  Post ReplyReply bullet Posted: 05 Oct 2015 at 5:14pm
I place order for my Apollo today.
My final configuration:
Intel Core I7 6700K 4.0GHz (overclock to 4.8GHz)
Mobo:ASUS Z170 PRO GAMING
16GB DDR4 2800MHz Digital Storm Certified Performance Series
Power Supply: 860W EVGA SuperNOVA
Optical Drive:DVD Writer/CD Writer
Storage Set 1:1x SSD ( 1TB Samsung 850 EVO)
Internet Access:High Speed Network Port
Graphics Card: 1x NVIDIA GeForce GTX 980 Ti  6GB (ASUS Strix Edition)
Sound Card:Integrated Motherboard Audio
Extreme Cooling :H20: Stage 2: Corsair H110i GT
Microsoft Windows 10 Home(64-Bit Edition)
Thanks to everybody who help me with helpful info.
Looking forward to read and communicate with you and learn some more.
The waiting officially start.Drooling
See you guys around.Big%20Smile
PS: One more question about my Power Supply. Its going to be enough for 2x GTX 980 Ti ? I'm gonna add second Ti in the future.
Gene.
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 05 Oct 2015 at 6:07pm
I7 13700KF 5.4hz
ASUS Dual 4070
32g ram@5200
850 Gold PSU
1TB SSD 2TB SSD
Zoofro View Drop Down
  Quote Zoofro Quote  Post ReplyReply bullet Posted: 06 Oct 2015 at 8:20am
One more question about my Power Supply. Its going to be enough for 2x GTX 980 Ti ? I'm gonna add second Ti in the future.Thank you in advance.
Gene.
Yes, a 850W PSU will be enough for 2x 980Ti. That's one thing that I overlooked when I had built my computer with DS was the PSU. Looks like I'll have to replace my PSU if I ever decide to get a 2nd Vid. Card. Oh well. Build looks solid, congrats!
Apollo
Intel Core i7 6700K 4.0GHz
16GB DDR4 2800MHz Corsair Dominator Platinum DHX
512GB Samsung 850 PRO
2TB Western Digital
  Quote chaby Quote  Post ReplyReply bullet Posted: 06 Oct 2015 at 12:14pm
Thanks for your help Zoofro.I'm sure you 'll enjoy your new machine as well.
                                        Gene.
  Quote db188 Quote  Post ReplyReply bullet Posted: 06 Oct 2015 at 3:35pm
you'll probably see ~100 watts pulled from the rest of the system, minus the vid cards. a single Strix ti vid card under load pulls ~425 watts (unless you oc it further).  a second card won't be working as hard as the first, but it will still add significant power draw (~225 watts extra).  so, you're looking at total system power draw in the 750 watts range under load.
youtube review: https://www.youtube.com/watch?v=Ixo1MRvMxxU
Edited by db188 - 06 Oct 2015 at 3:38pm
Aventum 3
I7-6700K
Gigabyte G1 Z170X Gaming GT
Corsair Hx1000i 1000W
Gigabyte M28U 4K
  Quote chaby Quote  Post ReplyReply bullet Posted: 06 Oct 2015 at 11:38pm
Thanks for clearing this out db188.
I can't wait for my baby to get home ( in good health).
                            Gene.
