USB Chassis Model questionPost Date: 2015-09-24 |
arnold1387
Newbie Joined: 11 Nov 2013 Online Status: Offline Posts: 10 |
Topic: USB Chassis Model question Posted: 24 Sep 2015 at 11:52pm |
i am think of get this base build
Configuration Code: 1288182 my question is about the USB plug on the Chassis specs it says 2x USB 3.0 and the Motherboard has 4x USB 3.0 8x USB 2.0 so does the Chassis only have 2 USB plugs? i need about 4 USB plugs do i need different chassis or am i missing some thing |
Quote Reply Posted: 25 Sep 2015 at 12:09am |
There will be USB ports on the front of the chassis (just left of the fans). There will also be additional ports from the rear I/O panel of the motherboard exposed on the back side of the computer. So, in short, the answer is 'no.'
arnold1387
Quote Reply Posted: 25 Sep 2015 at 12:19am |
ah ok thank you i thought that but wasn't sure
