Velox Build QuestionsPost Date: 2015-09-20 |
Facie
Newbie Joined: 20 Sep 2015 Online Status: Offline Posts: 15 |
Topic: Velox Build Questions Posted: 20 Sep 2015 at 6:21am |
I'm looking at the Velox and had a couple of questions.
1. It looks like the side of the case is permanently open (no window or plastic). Is that correct? If so, then, I have the following questions: A. Doesn't that make it a lot easier for dust, hair, etc to get into the machine? Of course, I suppose it makes it easier to get a can of air in there, but I wondering if dust is a bigger problem with an open case. B. Noise. Doesn't that make the internal noise much more noticeable? C. What's the point of paying for the additional noise dampening upgrade is the side is wide open? 2. On a related front to question 1.C, I currently have -------- and it's LOUD. What are folks' experience with the Velox build for noise? Thanks in advance for any and all responses! Facie Competitor name removed. Edited by Snaike - 21 Sep 2015 at 1:17am |
Quote Reply Posted: 20 Sep 2015 at 6:30am |
Hi Facie and Welcome to the forums.
The Velox does have a side panel. The pics show it removed to show off the internals. Here's a side shot with the panel..... Hope this helps. |
Quote Reply Posted: 20 Sep 2015 at 6:31am |
Plastic window I believe.
I don't believe there is any spot to install sound deadening material. The option is generic across all the builds. Edited by bprat22 - 20 Sep 2015 at 6:32am |
FrankW
Quote Reply Posted: 20 Sep 2015 at 8:02am |
Hi Facie,
What is noisy to you may be quite to someone else. Noise comes from fans, coolers, GPUs and power supplies. Currant PS are relative quiet and you can pick quiet fans. The latest GPUs don't kick in a fan unless it is really stressed. If you want a gaming machine then you will have a certain level of noise that is acceptable to gamers. You need to set your priorities as to what is most important to you. If noise is at the top of your list them you need to build accordingly. The Velox case is a super design for air cooling with high performance. With all of the perforations in the case you don't block much of the noise. Usually the Velox noise level is not bad and only loud at major levels of gaming. If I was concerned with noise levels then I would be looking at a Slade Build. It is designed with quiet performance in mind. It uses a relatively closed case with sound insulation. The problem is if you block noise you also block heat. So the thermals in the Slade are not as good as some other cases. It is not a problem as DS makes sure the thermals are under control with your build. Frank |
Facie
Quote Reply Posted: 20 Sep 2015 at 8:41am |
Frank -
Thanks for the quick and intelligent response. I appreciate it. I agree that "noise" is relative. But, I'm telling ya, my ------- is insanely LOUD by any subjective standard. LOL. Then again, it's a much older machine. I'm long overdue for an upgrade (hence my poking around here). ;-) Competitor name removed. Edited by Snaike - 21 Sep 2015 at 1:19am |
Facie
Quote Reply Posted: 20 Sep 2015 at 8:59am |
The Slade may be the way to go. Thanks for the tip. One question, it comes with a 750W power supply. If I want to add another 980Ti at a later date, will that be a big enough power?
Thanks! |
FrankW
Quote Reply Posted: 20 Sep 2015 at 9:42am |
The Slade is a custom build so you can pick and choose what components you want. I would select the 850w Super Nova. If you tell us your budget, you monitor resolution and your use/requirements, we can suggest some Slade builds for your consideration.
Frank |
jackbutler68
Groupie Joined: 08 Sep 2015 Online Status: Offline Posts: 202 |
Quote Reply Posted: 20 Sep 2015 at 10:06am |
I went with a Slade build. Even though it sacrifices airflow for a quieter system, if you need to you can give up some of the sound dampening for more airflow (remove the small side panel, add a fan or two). Also the case was less expensive than the Velox so I was able to spend a few more dollars on the components I wanted.
I only purchased a single 980ti but upgraded the psu to the Corsair 1000w so I can add a second card down the road. Also if you are getting a 980ti I recommend the Asus strix edition as it is only a few dollars more and comes factory overclocked. Edited by jackbutler68 - 20 Sep 2015 at 10:12am |
My DS Slade..
Corsair Obsidian 550D Intel Core i7 5820K 3.3GHz GIGABYTE GAX99SLI 32GB DDR4 2800MHz Corsair Vengeance LPX SSD 1TB Samsung 850 EVO NVIDIA GeForce GTX 980 Ti 6GB (ASUS Strix Edition) |
db188
Quote Reply Posted: 20 Sep 2015 at 7:11pm |
i honestly wouldn't recommend the "Slade" Corsair 550D "quiet" case to a "gamer". as a gamer, you will typically run your system under load for hours at a time, building up a lot of heat. an insulated case, known for sub par thermals (per several industry reviews) isn't exactly the case to build in with multi graphic's cards and hot, high-end oc'd components. go with a more all-around performer like the "Apollo" Corsair 760T full-sized ATX case. it has sub-30db (low fans) and sub-40db (high fans) fans with excellent-reviewed cooling performance both with average and "enthusiast" level hardware installed. the case comes with 2x 140mm intake fans and 1x 140mm exhaust fan factory installed. it has several water cooling options (up to 360mm radiator support) available.
if you're looking for a quiet work station, go for the Slade. Edited by db188 - 20 Sep 2015 at 7:15pm |
jackbutler68
Quote Reply Posted: 20 Sep 2015 at 7:41pm |
I am not sure why no one said this to me when I posted my configuration and said it was for gaming.....I hope I dont run into trouble with heat issues. I will not be very happy.....and I am getting a bit worried with all your negative posts on the Slade as a gaming case.....
My DS Slade..
Quote Reply Posted: 20 Sep 2015 at 8:01pm |
You can get a Slade to work in a gaming capacity if you are doing a water cooled configuration. You could either do a Hydrolux or do all all-in-one (AIO) coolers (like a H110i GT and EVGA 980 Ti Hybrid GPUs) where all of the radiators are mounted to be cooled with air directly from the outside of the case. Keep in mind this won't be the quietest possible configuration for the Slade as those will cool the CPU with air from inside the case and have the top panel closed.
Here's an example configuration of a Slade that can handle 4K gaming: Configuration URL: https://www.digitalstorm.com/configurator.asp?id=1285355 Specifications: Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: GIGABYTE Z170X-Gaming 3 (Intel Z170 Chipset) System Memory: 16GB DDR4 2666MHz Digital Storm Certified Performance Series Power Supply: 850W EVGA SuperNOVA Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (1TB Samsung 850 EVO) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 Ti 6GB (EVGA HYBRID Edition) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H110i GT - 280mm Radiator Liquid CPU Cooler (Extreme Performance) H20 Tube Color:- Not Applicable, I do not have a custom HydroLux liquid cooling system selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Standard Intel Turbo Boost 2.0 Automatic Overclocking Boost Graphics Card(s): Yes, Overclock the video card(s) as much as possible with complete stability Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) But the Velox shouldn't be too loud, either. The fans can be kept relatively low speed as there are so many of them moving a lot of air through the case. I'm sure it will be much quieter than your current set-up. |
Quote Reply Posted: 20 Sep 2015 at 8:02pm |
If you only have one GPU, it shouldn't be that big of a deal. It's when you have multiple that you can run into issues. |
jackbutler68
Quote Reply Posted: 20 Sep 2015 at 8:07pm |
Yeah but I wanted the option of adding another later. Hopefully it can handle 2.....lol
And I am doing a water cooled cpu with a 240mm radiator. Edited by jackbutler68 - 20 Sep 2015 at 8:09pm |
My DS Slade..
jackbutler68
Quote Reply Posted: 20 Sep 2015 at 8:11pm |
Sorry Facie didn't mean to hijack your thread.......
My DS Slade..
Quote Reply Posted: 20 Sep 2015 at 8:30pm |
There is a side panel that you can remove if it gets too hot for the GPUs. If that doesn't work, you can either add fans to the side panel or do a mod to the panel to try to open it up even further for more ventilation. You can also look at water cooling the GPUs, too, but with ASUS you will void the warranty if you remove or modify the cooler.
The 240mm rad for your GPU will be sitting up top with that panel open breathing in fresh air. Edited by - 20 Sep 2015 at 8:32pm |
jackbutler68
Quote Reply Posted: 20 Sep 2015 at 8:37pm |
Yes I knew about all of that and mentioned it earlier in this thread. From what I read it can be a silent case or a performance case with the panels removed and fans added but db188 keeps shooting it down as a gaming case even when I mention that so I was beginning to get a bit worried....lol
Edited by jackbutler68 - 20 Sep 2015 at 8:38pm |
My DS Slade..
db188
Quote Reply Posted: 20 Sep 2015 at 11:06pm |
why do all of that to a "silent" case? it defeats the purpose and there are much better options (as i have pointed out) for "all around performance". to make the Corsair 550D cool near the Corsair 760T (for example) you'd have to entirely remove everything that makes it a "silent" case. in fact, i bet at that point the 760T is actually more quiet. the HardOCP review had sound at and annoying 59db with the side panel removed! the saving grace is that you can run the interior fans at high rpm (due to the insulation) and keep the noise at 29db.
can you water cool a 550D? yes, with careful choosing of the right radiators and fans. even though you can get a 240mm rad in the top, it has to be a "thin" radiator with thin 120mm fans. read this article: http://www.hardocp.com/article/2012/08/08/corsair_obsidian_series_550d_midtower_case_review/5#.Vf-Zg5fNWCg now let's compare that to a review of the 760T: http://www.hardocp.com/article/2014/05/01/corsair_graphite_760t_full_tower_case_review/#.Vf9nv5fNWCh @jackbutler68, i've given this advice freely to anyone whose config showed a 550D case in it. as this person didn't really specify what exactly the needs were or what this computer would primarily be used for, i tailored my advice towards both gaming and productivity. this person is under no obligation to follow my advice. i have no agenda if that is what is being implied. i simply pointed out that the 550D trades excellent noise suppression at the cost of middling (at best) thermal performance if configured for noise suppression. if configured for thermal performance, there are far better choices to be made out there (and on this site). i'll leave it at that. |
jackbutler68
Quote Reply Posted: 21 Sep 2015 at 6:42am |
I wasn't implying anything. Everyone has their opinion and that's what people are asking for. Ultimately they will choose what they believe is best for them.
I chose this case because of the price, not because it was a "silent" case. I was getting a little worried about cooling with the comments you made, that's all. After reading up on it further I do not believe i will have any issues so I am happy. You want to hear a loud case, you should hear my ------- with the fans cranked up. Like a jet taking off...LOL Again Facie, sorry for hijacking your thread but it does give you some ideas about cases. Whatever you choose I am sure it will be fine and Digital Storm will build you a great computer. Removed competitor's name. Edited by Snaike - 21 Sep 2015 at 7:44am |
My DS Slade..
