Workstation for Autodesk products + PointcloudsPost Date: 2015-10-06 |
nt5k
Newbie Joined: 06 Oct 2015 Online Status: Offline Posts: 37 |
Topic: Workstation for Autodesk products + Pointclouds Posted: 06 Oct 2015 at 9:28am |
Under3500 Expectations: Fast, reliable, quiet, 4 years plus of service Usage: Home workstation: AutoCAD (w/ large pointclouds), Revit, Recap, Bluebeam. Special Needs: Windows 10 vs Windows 7.... (Waiting for Autodesk certification on Revit and Recap.) Do I gamble and go w/ 10? I'd like to run 4 monitors. Two of them 4k. Saved Ticket #:1293690 Specifications: Digital Storm Slade (Config # 1294347) Chassis Model: Corsair Obsidian 550D Core Components Processor: Intel Core i7 5930K 3.5GHz (Six-Core) (Unlocked CPU) Motherboard: GIGABYTE GA-X99-SLI (Intel X99 Chipset) System Memory: 32GB DDR4 2800MHz Digital Storm Certified Performance Series Power Supply: 1000W Corsair HX1000i (Digitally Controlled Power) Storage / Connectivity Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (250GB Samsung 850 EVO) Storage Set 2: 1x Storage (2TB Western Digital - Enterprise Edition) Internet Access: Wireless PCI-E ASUS PCE-N53 (Dual Band Performance) (Supports 802.11n/g/b) Graphics / Multimedia Graphics Card(s): 1x NVIDIA Quadro K2200 4GB (Outputs: 1x DVI-D ; 2x DisplayPort 1.2) Sound Card: Integrated Motherboard Audio Digital Storm Engineering Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Chassis Fans: Standard Factory Chassis Fans Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material) Digital Storm TwisterBoost Technology Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires High-End Motherboard Selection) Software Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) (FREE Upgrade to Windows 10) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Accessories / Goodies Customer Care Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 4 Year Limited Warranty (4 Year Labor & 2 Year Part Replacement) To get this build to work w/ the 5930k I had to pick the 2 GPU Slade and modify. (5930 because of Autocad multi-threading when manipulating a PC.) Concerning the size of the SSD: do I store any work data on the ssd? Or is this strictly for the OS & apps? Am I over-killing anything? I'm new at this (trying to spec a pc). So I'f it looks like I have no idea, that may be the case. Regards. |
db188
Quote Reply Posted: 06 Oct 2015 at 3:50pm |
if this isn't to be used to game on then this might serve you better:
Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Xeon E5-2630 v3 (8-Core) 2.4GHz (8 QPI) (20MB Cache) (Extreme Performance) Motherboard: GIGABYTE GA-X99-SLI (Intel X99 Chipset) System Memory: 64GB DDR4 2133MHz (ECC Registered) (16GB x 4) Power Supply: 750W EVGA SuperNOVA (750 B1) Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (1TB Samsung 850 EVO) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA Quadro K2200 4GB (Outputs: 1x DVI-D ; 2x DisplayPort 1.2) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a custom HydroLux liquid cooling system selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Standard Intel Turbo Boost 2.0 Automatic Overclocking Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) $3,586 |
Aventum 3
nt5k
Quote Reply Posted: 07 Oct 2015 at 5:54am |
Interesting...
Thank you db188 Any thoughts on the windows 7 vs 10? |
db188
Quote Reply Posted: 07 Oct 2015 at 10:57am |
i think W10 is still working out the compatibility kinks, but if you're going with a new system build, you might as well upgrade now. a couple of friends have upgraded and they don't report any issues.
Aventum 3
Zoofro
Newbie Joined: 21 Sep 2015 Online Status: Offline Posts: 47 |
Quote Reply Posted: 07 Oct 2015 at 1:18pm |
I upgraded my current computer to Windows 10 the day it went live. Have had zero incompatibility problems since then. Pretty flawless thus far and went with Windows 10 for my new computer.
Apollo
Intel Core i7 6700K 4.0GHz ASUS Z170 PRO GAMING 16GB DDR4 2800MHz Corsair Dominator Platinum DHX 512GB Samsung 850 PRO 2TB Western Digital NVIDIA GeForce GTX 980 Ti |
nt5k
Quote Reply Posted: 08 Oct 2015 at 6:58am |
From what I'v read, recap and revit will load/run on a wdw 10 machine that was upgraded from 7 (or 8). Clean wdw 10 machine = no bueno. I can pawn my revit work off for a bit, but I must be able to run recap...
nt5k
Quote Reply Posted: 08 Oct 2015 at 9:01am |
May pull the trigger today:
Digital Storm Slade (Config # 1295068) $3,337.00 Chassis Model: Corsair Obsidian 550D Processor: Intel Xeon E5-2630 v3 (8-Core) 2.4GHz (8 QPI) (20MB Cache) (Extreme Performance) Motherboard: GIGABYTE GA-X99-SLI (Intel X99 Chipset) System Memory: 32GB DDR4 2133MHz (ECC Registered) (8GB x 4) Power Supply: 750W EVGA SuperNOVA (750 B1) Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (500GB Samsung 850 EVO) Storage Set 2: 1x Storage (2TB Western Digital - Enterprise Edition) Internet Access: Wireless PCI-E ASUS PCE-N53 (Dual Band Performance) (Supports 802.11n/g/b) Graphics Card(s): 1x NVIDIA Quadro K2200 4GB (Outputs: 1x DVI-D ; 2x DisplayPort 1.2) Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Chassis Fans: Standard Factory Chassis Fans Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) (FREE Upgrade to Windows 10) |
Alex
Quote Reply Posted: 08 Oct 2015 at 9:57am |
Looks like a solid build!
nt5k
Quote Reply Posted: 16 Oct 2015 at 9:55am |
I read somewhere that Xeon's were "locked" and could not be overclocked. Today DigitalStorm confirmed that.
Quote Reply Posted: 16 Oct 2015 at 10:05am |
Yep, only the "K" and "X" processors are unlocked. The Xeon's are locked as they are focused on stability, something overclocked processors are not known for.
Caleb
Groupie Joined: 19 Jul 2009 Online Status: Offline Posts: 354 |
Quote Reply Posted: 16 Oct 2015 at 2:10pm |
I use windows 10 on my new DS Laptop and it runs very well. I like it just as much and maybe a tad more than Windows 7. It's a fantastic OS. I'd take the upgrade.
