Back with another build for review.
Post Date: 2016-04-16
Shakey View Drop Down
  Quote Shakey Quote  Post ReplyReply bullet Topic: Back with another build for review.
    Posted: 16 Apr 2016 at 10:23am
For those who might not have seen it, I previously submitted a build for review here. I am still researching to decide exactly what I want and made this build with the Hailstorm II that I really like.
$2000 - $3000 (That was my original thoughts, but I went over that on this build).
Run games smoothly. I currently use only one monitor although I have been thinking about getting a second.
Gaming (Fallout 4, GTA 5, just as examples of what I play), general usage and likely VR with the Oculus Rift later in the year.
I originally chose the Slade because I live in the desert and dust is an issue. I am not sure that I want that to be a determining factor though. That should be that I get what I want and not necessarily what I think I might just need.
One question that I do have is regarding the liquid cooling. I have never owned a liquid cooled computer before. Are there any maintenance requirements or info that would be good to know beforehand?
As always, I appreciate any feedback!
Thanks.
Shakey
Saved Ticket #: 1400676
https://www.digitalstorm.com/configurator.asp?id=1400676
Chassis Model: Special Deal Hot Seller - Hailstorm II Edition
Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core)
Motherboard: ASUS Z170 PRO GAMING (Intel Z170 Chipset) (Up to 5x PCI-E Devices)
System Memory: 16GB DDR4 2666MHz Digital Storm Certified Performance Series
Power Supply: 750W EVGA SuperNOVA (750 B1)
Storage Set 1: 1x SSD (512GB Samsung 850 PRO) <br><strong></strong>
Storage Set 2: 1x Storage (2TB Western Digital - Black Edition) <br><strong></strong>
Graphics Card(s): 1x NVIDIA GeForce GTX 980 Ti 6GB (VR Ready) <br><strong></strong>
Extreme Cooling: H20: HydroLux LITE: Integrated Cooling System (1x Graphics Card + CPU) <br><strong></strong>
HydroLux Fluid Color: Red Fluid (Requires HydroLux Liquid Cooling System)
Chassis Fans: Corsair Airflow Performance Edition (Up to 6 Fans) <br><strong></strong>
Airflow Control: - No Thanks
Branded Gear: T-Shirt - Black (Extra Large) <br><strong></strong>
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 16 Apr 2016 at 10:34am
The Hydrolux LITE is an AIO cooler like the Corsair H100 series, but with a stronger pump and water-block and the loop can be broken to add components.  It's considered maintenance free for the 3 year warranty period.  Then a fluid refill is recommended.  Its built off the Swiftech H220-x if you want to do further research.
