\Pleae Help
Post Date: 2008-11-08
saryan View Drop Down
  Quote saryan Quote  Post ReplyReply bullet Topic: \Pleae Help
    Posted: 08 Nov 2008 at 6:02am
Just got my new rig and pics will be coming very soon.  I just need some quick help.  It did not fitu under my desk as my last one did and that is fine.  I have place it on top of my desk.  Only problem is that the internal fans sound very loud and my wife is not happy about that.  Can someone tell me how I can access the bios and turn them down and how low I can do it?  Sorry I am a noob when it comes to these things.  My spec is below.  I suspect that the loudest noise I hear is the video card.  Thanks!
Hard Drive 1: 150GB Western Digital VelociRaptor (10K RPM) (16MB Cache) (SATA) (Extreme Speed)
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card(s): NVIDIA GeForce GTX 280 1GB (Includes PhysX Technology)
TV Tuner: - No Thanks
Modifications: - No Thanks
Protection: - No Thanks
Pre-Install Game: - No Thanks
LCD Display: - No Thanks
Dog Lover View Drop Down
  Quote Dog Lover Quote  Post ReplyReply bullet Posted: 08 Nov 2008 at 9:20am
I have got to strongly agree with Harley on this.
You must understand that you now have a real gaming computer.  It’s not meant to be quiet and docile.  It’s meant to be a gaming beast and that’s, I assume, why you bought it.
Mine too is HUGE. It would not fit in my desk, so I have it setting on the floor beside my desk.  It is, yes, much louder than my old rig.  But, you know, when I hear those fans kick in and that Thermoelectric cooling fluid rushing around, I get giddy because I know I am crushing every game I throw at it with ease!
So, please, do not monkey around with any fan speeds…Unless your wanting to step them UP to keep is cooler!
Hey, you don’t trade in your four cylinder Ford Escort for a V12 Viper and later complain about engine noise, right?
It’s the exact same thing, my friend.
Embrace the power!  It is glorious!
Extreme Case
850 Watt Thermaltake
Qx6850 3.0 Ghz (stock speed)
780i Motherboard
4 G, 1066 RAM
2X SLI GTX 260, 896
Sound Blaster X-Fi XtremeGamer
Thermoelectric Liquid Chilled
Windows 7,64b
  Quote saryan Quote  Post ReplyReply bullet Posted: 08 Nov 2008 at 9:51am
Thanks for all the help.  One more quick question, if I place it on the flooe it will be on carpeting.  Should I get some wood at the local hardware store to place it on, or should it be fine.  I really appreciate all the feedback!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Nov 2008 at 12:48pm
saryan do you know what your temps are right now? people can't tell your temps are from here.
if your temps are OK with surfing and such you can turn the fans down and then just raise them again when you are ready to game, they don't have to run high all the time if its not needed.
to know if we can do that or not we need to know your temps, then turn the fans down a bit and see what the temps are again, if the temps are fine then we keep going if not we stop.
first thing you want to be sure of is that the system has plenty of room on sides, back and top for proper air flow.
Edited by DST4ME - 08 Nov 2008 at 12:48pm
  Quote saryan Quote  Post ReplyReply bullet Posted: 08 Nov 2008 at 3:02pm
Thanks for all the help!  Believe it or not, my wife suggested a setup that looks great and I am already used to the noise, sounds like a sweet pur.  Ouch
I posted pics online,let me know what you think.
PS:  In the future how can I check my temps?  I am a noob.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Nov 2008 at 5:30pm
HWMonitor
can tell you your temps
  Quote saryan Quote  Post ReplyReply bullet Posted: 08 Nov 2008 at 9:32pm
Thanks the HW Monitor program recorded the following MAX temps:
CPU: 45C
AUX: 29C
Intel Quad
Core 0: 55C
Core 1: 46C
Core 2: 47C
Core 3: 49C
Geforce GTX 280 Core: 41C
The CPU Fans are running at 2410 and 743 without any manipulation on my part.  Anything anyone can let me know about what these numbers mean in terms of cooling performance?
