1 st ever custom build comp / please help review
Post Date: 2009-11-16
ntourniquetn View Drop Down
  Quote ntourniquetn Quote  Post ReplyReply bullet Topic: 1 st ever custom build comp / please help review
    Posted: 16 Nov 2009 at 2:25am
So I've gone through a bunch different configuration and probably would settle with the following:
Chassis Model: Special Deal Hot Seller - Cooler Master Elite 310
Hard Drive Set 1: Operating System: 1x (1TB Seagate/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Video Card: 1x NVIDIA GeForce GTX 285 2GB (Includes PhysX Technology)
I've deleted the parts that are N/A,
Besides the above setting, I'm going to get 6gb more ram.
So any problem in my build?
(if things all fit in? enough cooling? enough power supply? compatibility issue with OC, 12 GB ram, GTX 285?)
THANKS!!!!!!!!!!!!!!!!!
Edited by ntourniquetn - 16 Nov 2009 at 8:12pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 4:52pm
what is your budget? and what resolution will you be gaming at? what is the main use of this pc?
  Quote ntourniquetn Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 8:11pm
my budget is 2000-3000. in fact below 2500 would be better.
I do play crysis warhead and similar games in the future.
primarily I use this computer for heavy illustrator, photoshop work and intensive CAD, rhino and maya renderings.
my dual monitor is ASUS and DELL 22", so I won't be gaming beyond 1680x1050.
Edited by ntourniquetn - 16 Nov 2009 at 8:16pm
  Quote ntourniquetn Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 8:13pm
also I Love liquid cooling but I'm reluctant for security and maintainence issues.
let me know if liquid cooling is safer for long range shipping and how often it needs to be maintained
Sarah View Drop Down
Hardcore Gamer
  Quote Sarah Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 8:20pm
Check it out, I would go with something like this, and its within your budget...
Ticket Number: 354163
Trim Accents: - Not Available
Hard Drive Set 1: Operating System: 1x (1.5TB Seagate Barracuda (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Enhancements: - Not Available
Chassis Mods: - Not Available
Boost Memory: - Not Available
Boost OS: - Not Available
Office: - Not Available
Benchmarking: - Not Available
Sarah
  Quote ntourniquetn Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 8:40pm
Thanks Sarah,
Although
1. I wonder if I must have the 1000W supply, I don't think I will ever go with triple video card.
2. Is dual GTX 275 better than single GTX 285, though I wish I can have dual GTX 275 at 1.7GB each, but this option is not available on this build.
3. as I noted above, can I get an additional 6 GB ram on my own? can this build take 12 Gb at 1600 MHz?
THANKS!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Nov 2009 at 9:47pm
as for Sarah's build, the only thing I would change is the 1.5TB HDD, they don't have a good track record so far, change that to veloci or ssd.
Nvidia system:
Here you go Ticket# 354183 --- Price: $1891 (To see this build click here) Price after current promotion $1891
Video Card: 1x NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Ati system:
Here you go Ticket# 354184 --- Price: $2045 (To see this build click here) Price after current promotion $2045
here is some info:
liquid cooling is air tight and should leak but at the same time, nobody can guarantee you 100% that nothing will happen during shipping, if you have a crate, odds are you should be ok but thats not 100%.
1 x 275 896MB is only 3 to 5 fps slower then 1 x 285 2GB, and at your resotlution you won't even notice the difference.
as for crysis, if you want to play at highest settings, you might want to go with 2 x 275 896MB or 1 x 5870, but most other games like cod, farcry2, left for dead and etc, just need 1 x 275 or 1 x 5850 to play at highest settings.
yes you can add 6GB of ram yourself but its best to let DS do it, as you might need to redo your oc.
Edited by DST4ME - 16 Nov 2009 at 9:48pm
