120mm Case Fans
Post Date: 2009-11-16
EdH63 View Drop Down
  Quote EdH63 Quote  Post ReplyReply bullet Topic: 120mm Case Fans
    Posted: 16 Nov 2009 at 10:09pm
One of my 120mm case fans is taking a dump on me and I'm going to replace both in the top of my TJ-09 case.    What would the recommendation be out of these choices?  I have two Cooler Masters there now.  Noise?  RPM?  CFM?  Bearings vs. fluid.
Antec / Cooler Master / Scythe USA
Edited by EdH63 - 16 Nov 2009 at 10:30pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 12:04am
you got a link? each builder has different speed fans with different cfm at that size.
I would choose based on which ever has the highest cfm with loweset dba.
scythe is a good one but the other 2 are ok too.
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 12:12am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 1:15am
choose one below 20 dba and as high cfm as you can find.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 8:55am
the Gentle Typhoons are the best out there for the amount of air flow compared to the noise level.. even at the same Db as other fans, they have a different sound that is not annoying like most fans.. They are also some of the best on Radiator fans also...the 1450 RPM are silent, the 1850's make a little noise, but quieter than anything I have ever seen.
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 17 Nov 2009 at 9:03am
I believe I will go with Scythe.  Thanks ladies.
