140mm fan replacements
Post Date: 2012-08-29
kernols View Drop Down
  Quote kernols Quote  Post ReplyReply bullet Topic: 140mm fan replacements
    Posted: 29 Aug 2012 at 4:49pm
Hello Everyone,
Im looking for fan replacments for the 800d. specifically the 140mm case fans. (hd fan, back fan and lower fan by the power supply.)  anyone have any recommendations? ive looked around and have seen alot of different answers. im getting alot of noiseblocker fans though
  Quote Alex Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 5:44pm
Corsair's new line of fans are quite good.
http://www.corsair.com/en/air-series-af140-quiet-edition-high-airflow-140mm-fan.html
  Quote kernols Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 5:46pm
Okay ill take a look, while i do, are the cougar vortex fans any good?
tju76 View Drop Down
  Quote tju76 Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 6:16pm
I picked up a set of nzxt fans not sure the specific model but they are black with white blades
  Quote kernols Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 6:17pm
I guess it would help if i say what colors im looking for lol. my theme for the rig that i ordered TODAY actually :) is red and black.
  Quote tju76 Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 6:27pm
I think white would like sharp in there. What do you want quite fans or fans that will move a lot of air
Led or non led
  Quote kernols Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 6:29pm
Non led ,  mix between high cfm for the case and quiet. im just changing the 3 140's so im guessing i want high cfm and not worry about static pressure
Edited by kernols - 29 Aug 2012 at 6:29pm
  Quote kernols Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 6:33pm
The new corsair fans look nice and sound quiet but do they have a much improved airflow over the stock ones? the stocks are rated for 69 cfm. the new ones are only 6.
*edit* just saw a post and the stock fans are not 69. they are only 49.6. corsair hasnt changed it yet on their website. so the new corsair ones might work then
Edited by kernols - 29 Aug 2012 at 7:02pm
  Quote kernols Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 6:36pm
The cougar vortex fans have really high cfm and aren't all that loud but i read they are noisy and annoying when placed horizontally. too bad cuz they are orange and the cold cathodes give off a slight orange look too
  Quote tju76 Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 8:36pm
You can buy better fans then the corsair brand ones
  Quote kernols Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 8:39pm
how about the noiseblocker pk3's?
http://www.noiseblocker.de/en/BlackSilentPro140.php
read alot of ppl using these with good results. they are good for both vertical and horizontal
surf71zx View Drop Down
  Quote surf71zx Quote  Post ReplyReply bullet Posted: 07 Sep 2012 at 3:31pm
You cant go wrong with the noiseblocker fans.DS installed these in my system  and there quiet.Move tons of air but there expensive.
  Quote kernols Quote  Post ReplyReply bullet Posted: 08 Sep 2012 at 6:18pm
I went ahead and bought some noiseblockers. my system hit stage 7 today and everything passed:) pretty anxious for it to arrive.
  Quote Alex Quote  Post ReplyReply bullet Posted: 08 Sep 2012 at 6:50pm
