$1500 build help
Post Date: 2009-10-30
joshjohansen View Drop Down
  Quote joshjohansen Quote  Post ReplyReply bullet Topic: $1500 build help
    Posted: 30 Oct 2009 at 2:47pm
Hey everyone, I haven't built a computer in almost 7 years, and finally that computer is dying and it's time to upgrade.  I have spent the past couple months trying to figure out what I wanted to do, and here is what I came up with.  My budget is $1500 and I am trying to make it as future proof as possible.  I would appreciate any advice or comments, especially if there is something that I am missing with what I am putting together.  Thanks guys.
ASUS P6T LGA 1366
Core i-7 920
Corsair 6GB Kit TR3X6G1600C9
Antec 300
Antec TP-750 Power Supply
XFX Radeon HD 5770
WD Caviar Black 500GB
Samsung DVD RW
Acer 24" H243H
Microsoft Windows 7 Professional 64 bit OEM
Price - $1488.88
Thanks again for your help!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Oct 2009 at 2:48pm
I would go with corsair psu, and haf 922, mobo go with evga, better support and such.
Edited by DST4ME - 30 Oct 2009 at 2:49pm
  Quote joshjohansen Quote  Post ReplyReply bullet Posted: 30 Oct 2009 at 6:39pm
Is there any reason why?  Better cooling etc?  Does everything else look like the right way to do it?  Thanks a lot.
  Quote joshjohansen Quote  Post ReplyReply bullet Posted: 30 Oct 2009 at 6:43pm
I just saw the evga comment.  what board would you recommend from them?  everything i read said asus was the way to go.  Also, is the haf 932 worth an extra 100?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Oct 2009 at 11:41pm
evga has better support and warranty, the HAF gives you much better airflow stock, it has more fans and its fans are bigger also, its much easier design to add HDDs and etc.
  Quote joshjohansen Quote  Post ReplyReply bullet Posted: 31 Oct 2009 at 9:00am
Edited by joshjohansen - 31 Oct 2009 at 2:33pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 31 Oct 2009 at 2:20pm
I would go with the 850w corsair psu.
btw I think you listing the specs broke this part of the board, go back and edit your post.
  Quote joshjohansen Quote  Post ReplyReply bullet Posted: 31 Oct 2009 at 2:38pm
Ok I edited the post, here is currently what I have.  I am missing a 24" monitor, but am having issues finding one with USB's for a good price and also the video card, which I am leaning towards a 5850.  So far I am at 1145, if I add the video card and monitor I am going to be at 1650.  But if it costs me an extra 150 to get exactly the right thing then I guess its worth it.  Thoughts?  Thanks again for any help...
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C9
Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.
 PLEXTOR 24X DVD/CD Writer Black SATA Model PX-880SA LightScribe Support
 COOLER MASTER Silent Pro 700 RS-700-AMBA-D3 700W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply
    COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
 EVGA 141-BL-E757-TR LGA 1366 Intel X58 ATX X58 SLI LE Intel Motherboard
    Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders
    Intel Core i7-920 Bloomfield 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920
COOLER MASTER Intel Core i7 compatible V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 31 Oct 2009 at 2:49pm
for 1900 x 1200 res you gonna want the 5870.
