1st build ever help!
Post Date: 2011-10-14
jmart View Drop Down
  Quote jmart Quote  Post ReplyReply bullet Topic: 1st build ever help!
    Posted: 14 Oct 2011 at 4:14am
So this is my first build ever
Im looking to buy I top of the line gaming pc to replace my old gaming laptop
Uses: Lots of gaming (specifically skyrim on high settings right now) some video streaming and other usage
what I have so far: I couldn't figure out how to put the build in here so here is the ticket number 605561
Any comments or advice would be appreciated I don't want to go any higher in price but would definitely be willing to go lower
Thanks
ArchiSurf View Drop Down
  Quote ArchiSurf Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 5:03am
I think it'd help the experts, that'll come in later to provide help, to know what the resolutions are you planning to use.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 6:09am
lol a big NO to that config.
as AS mentioned, what res you gonna be gaming at with this pc?
  Quote jmart Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 12:20pm
really? dang
I think im going to go with 1920 x 1080
also I forgot to mention i wanted to make really good future proof
Thanks for any help!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 2:56pm
There is no such thing as future proof, more power now does not mean you will be fine later.
anything over what I have down the there you would not notice the performance difference from, and by that I mean I can come and replace whatever config you make with the one below that I made and unless I told you I made the change you would never notice, well something in my build is faster so might notice my build performing better:
Here you go Ticket# 605640 --- $3,483 (To see this build click here)
Expansion Bay: Internal Digital Media Card Reader (Black)
Optical Drive 1: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) (Lite-On iHBS112)
Sound Card: Creative Labs X-Fi Titanium Fatal1ty Professional
Extreme Cooling: H20: Stage 4: Sub-Zero LCS Cooling System: CPU Only
H20 Tube Color:White Tubing with High-Performance Fluid (UV Lighting Reactive)
if you want your pc to be future proof in games, then upgrade your sli every 2 to 3 years.
Edited by DST4ME - 14 Oct 2011 at 2:57pm
  Quote jmart Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 3:14pm
interesting... I had a couple questions
First do you think its worth it to wait for the new intel sandy bridge-e processors?
Second, is the added price of a SSD better than to non SSD's in RAID?
Third, whats the difference between the nvidia 570's and 580's?
Fourth, whats the difference between the Chassis?
Last could I add a tv tuner to that motherboard?
Once again thank you for your help
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 3:23pm
1. For 1900 x 1200 res there is no reason to wait.
2. you can raid 10 hdds together you still won't get ssd speeds, 4k speeds don't change in raid, seektime barely gets better in raid.
3. where it counts very little.
4. lot of differences but the hailstorm is for system with full lc cause it does not have great airflow, the haf x is king in airflow.
5. oh sorry, I forgot to put your tv tunner back, yes you should be able to just add the tv card to my config, just click on it and add it in.
notice everything I removed is because you won't want it or its performance gain was little but stress or heat was gonna be more problem then the little performance gain.
  Quote jmart Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 3:44pm
yes this is my first attempt at a custom pc and I did not really think about stress/heat
on a system with a SSD and non SSD what should I put on each? Main operating system on SSD and games on other or reversed?
Also do I still need the LC with the haf x and with the haf x is it  easy to upgrade components later?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 3:47pm
you never need lc unless you are a benchmarker.
case does not play a big part in upgrading components but what components did you have in mind?
  Quote jmart Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 8:17pm
ok cool
I was just thinking that if I ever wanted to upgrade my motherboard or something I was wondering how easy that would be
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 8:20pm
Woooo, upgrade mobo? you don't hear that all the time, upgrade mobo pretty much means new pc, cause with that upgrade you will need new ram/cpu and between those 3 you are looking at a new pc pretty much.
but if you know how to change mobo, you should be good to go with a big case like haf, all that room make it easier to work in, and in this kind of upgrade case does matter, I was thinking you were thinking about upgrading gpu/ssd/hdd and things like that lol.
  Quote jmart Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 8:30pm
ok sweet that sounds good...Thanks for all your help!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 10:47pm
My pleasure and good luck
