1st custom build for gaming & graphics - advice?
Post Date: 2012-02-13
capto0924 View Drop Down
  Quote capto0924 Quote  Post ReplyReply bullet Topic: 1st custom build for gaming & graphics - advice?
    Posted: 13 Feb 2012 at 8:20pm
[2600-2800]
[Ultimately using it for gaming - occasional graphic design/flash work - Hoping to play all games on maxed out settings - currently running at 1600x1200 x2 - dual monitor setup. Is SLI really going to make that much of a difference?]
[Games and medium to heavy graphic work]
[Games - see above - I will most likely but installing my existing 320gig HDs x2 SATA]
Saved Ticket #: [655052]
Chassis Model: Special Deal Hot Seller - Corsair 650D
Power Supply: 850W Corsair TX850 V2 (Dual SLI Compatible)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition)
Optical Drive 1: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) (Lite-On iHBS112)
Video Card: 1x NVIDIA GeForce GTX 570 2.5GB (Includes PhysX) (EVGA 025-P3-1579-BR)
Extreme Cooling: H20: Stage 2: Corsair H100 Liquid CPU Cooler (240mm Radiator) (Extreme-Performance Edition)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans)
Recovery Tools: Advanced Recovery Kit (40GB Hard Drive Partition of Image With OS & Drivers)
Office: Microsoft Office 2010 Office Home and Business (PC Attach Key PKC)
Edited by capto0924 - 13 Feb 2012 at 8:26pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 14 Feb 2012 at 7:11am
Hi capto0924...
Sli does make a diiference if you want to max out games.  Your resolution is borderline need or not need, but to build a system like this and not sli would be a mistake.  Example...23"monitor at 1920x1050 res definitely needs sli to max
If you do go sli the ps is 1050HX.  The case we recommend the HafX as it's the best for cooling.  But, as always, your call.
The x79 platform you picked, Asus X79mobo and 3930k cpu,  with blu-ray, MS Ofiice would be close to $3500 with sli.
The p67 platform, p8p67 deluxe with i7-2600k and MS Office, bluray would be about $2800 with sli.
The x79 platform does have 6 core cpu and the mobo has quad channel memory for video editing,heavy graphics work. The p67 is a 4 core cpu and dual channel memory.  I don't know much about graphics or the requirment s so your call.  You know more than IBig%20Smile
 Lots to look at.
 Let us know what you think..Big%20Smile
Edited by bprat22 - 14 Feb 2012 at 7:18am
