2 month old Vanquish Lvl 4, rear fan not spinning
Post Date: 2014-05-28
HauntedKrist View Drop Down
  Quote HauntedKrist Quote  Post ReplyReply bullet Topic: 2 month old Vanquish Lvl 4, rear fan not spinning
    Posted: 28 May 2014 at 2:49pm
So I just noticed something on my Corsair case, the rear exhaust fan is not spinning. And looks like it's jammed into the side a bit. However the internal rear fan attached to the water cooling unit is spinning just fine. Is this normal? Do they disable the rear case fan normally?
Ariktu View Drop Down
  Quote Ariktu Quote  Post ReplyReply bullet Posted: 28 May 2014 at 11:51pm
All my fans are spinning.
Is the fan plugged in? is there anything preventing the fan from spinning?
  Quote Snaike Quote  Post ReplyReply bullet Posted: 29 May 2014 at 12:20am
Vanquish I or Vanquish II? I know on the II all the fans spin, but you mention water cooling... leads me to think it's a Vanquish I.
Can't see why they unplug a fan even with cooling.
So, I'm no help.
Edited by Snaike - 29 May 2014 at 1:41am
  Quote HauntedKrist Quote  Post ReplyReply bullet Posted: 29 May 2014 at 9:34am
Vanquish I
So here's an update. I stuck a small screwdriver in, and tapped the fan, and it started spinning again. Only problem is it would make an annoying clicking/rattling sound while gaming.
Turned the thing off and unplugged, tried prodding the fan a bit with the screwdriver again. Turned it back on and it was even louder.
So I booted up Crysis 3, which kicks the fan into overdrive, and it was SUPER loud with the clicking/rattling.
So i grabbed another screwdriver and tried loosening the screws on the rear grill, loosening one screw made the clicking stop for a bit, but i booted up Crysis 3 again and the clicking continued.
So i left the game running, and continued to f**k with adjusting the tightness of the rear screws, till finally i got the rattling to stop completely, now it's whisper quiet.
Now, that being said, should I be worried at this point? Do you think the fan itself is on the fritz or just the centering of it in the case was the problem?
Edited by HauntedKrist - 29 May 2014 at 9:35am
danjw1 View Drop Down
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 29 May 2014 at 9:39am
I would contact DS and see if they will send you a new fan.
  Quote HauntedKrist Quote  Post ReplyReply bullet Posted: 29 May 2014 at 10:28am
I did and never received a tech callback. How hard is it to reinstall a new closed loop water cooler? Same as any heat sink?
  Quote Ariktu Quote  Post ReplyReply bullet Posted: 29 May 2014 at 2:31pm
I must admit to not being sure how hard it would be to reinstall the water cooler would be. I would try calling DS again or emailing them.
I believe Alex's email address is [email protected]
  Quote Alex Quote  Post ReplyReply bullet Posted: 29 May 2014 at 3:00pm
@HauntedKrist,
Sorry to hear. I just checked your order and I see that our team contacted you earlier in the day and the issue seems to be resolved for now. Feel free to contact us if you still have any issues.
Time to enjoy your PC!
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 29 May 2014 at 3:08pm
  Quote HauntedKrist Quote  Post ReplyReply bullet Posted: 30 May 2014 at 1:20pm
@HauntedKrist,
Indeed, it has been rattling off and on for the past day or so still, I kept trying to readjust the screws, and I think I finally got it to the point where it's noise free. But man those fans are sensitive.
Here's hoping it doesn't cause anymore issues.
This page was generated in 0.1074219 seconds.
