2 Towers,1 Monitor
Post Date: 2008-09-28
Jail Bird View Drop Down
  Quote Jail Bird Quote  Post ReplyReply bullet Topic: 2 Towers,1 Monitor
    Posted: 28 Sep 2008 at 9:20pm
After recieving my new rig from DS I will have two computers, a Samsung 22" LCD Monitor w/dual inputs (automatically switchable), one key board and one mouse.
How can I control the two pc's with one mouse and one keyboard ... what is the best solution, without interfering with gaming ?
lighn'ing fps
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Sep 2008 at 9:55pm
  Quote Jail Bird Quote  Post ReplyReply bullet Posted: 29 Sep 2008 at 5:23am
I have seen this, but it stresses TWO monitors ... I wonder if it will work when I only have one ?
lighn'ing fps
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Sep 2008 at 5:32am
OH I see what you mean then you need a kvm switch check here
Swinder6kz View Drop Down
  Quote Swinder6kz Quote  Post ReplyReply bullet Posted: 29 Sep 2008 at 5:37am
I saw a video about synergy on cnet, it looks very cool but my only issue would be running my mouse off my screen while I'm gaming and having no clue where it went.  I wish there was a way to pop back and fourth using keystrokes like a kvm switch without the price tag.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Sep 2008 at 5:49am
I thought you could do a screen lock, have you checked their site?
  Quote Jail Bird Quote  Post ReplyReply bullet Posted: 29 Sep 2008 at 5:50am
So you can use a KVM switch w/o using the video port ?
See I would not need to (and would prefer not to) since I have dual inputs on my single monitor ...
lighn'ing fps
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Sep 2008 at 5:59am
You connect each pc to kvm then connect monitor to kvm.
Bouke285 View Drop Down
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 03 Oct 2008 at 6:23pm
DST4ME you know a lot about computers you should work for Digital Storm :P
I know the plans I have for you, declares the Lord, plans to prosper you and not to harm you, plans to give you hope and a future." (Jeremiah 29:11)
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 04 Oct 2008 at 11:52am
KVM Switch
Keyboard...Video....Monitor...
DeadDead the only issue with them is if you want to use DVI there arent very many that are good unless you pay 200+ $
  Quote Jail Bird Quote  Post ReplyReply bullet Posted: 04 Oct 2008 at 12:10pm
Well, what I'm going to TRY is this:
I'm going to use my Cyber Snyper keypad, on the gaming (new DS) tower,flop over my Razor mouse from my present tower,and get a wireless mouse for my other tower,keeping my present keyboard right where it is (& hooked to my "old" tower)
this way, the cyber sniper is the size of your hand and will not clutter the desk, and the mouse is small so I'm not worried about it. Make any sense ? I dunno .. I'll try it ...
thought of also buying two wireless gaming devices (keyboard/mouse) install the drivers on both towers, set up the xmitters in the backround, but only actually use one each of the devices.... know what I mean ??
lighn'ing fps
  Quote Jail Bird Quote  Post ReplyReply bullet Posted: 04 Oct 2008 at 12:12pm
buying two gaming mice/keyboards and only using one seems like a waste but is still cheaper than a good kvm
lighn'ing fps
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Oct 2008 at 3:15pm
let us know what you think once you gotem
aperrigo View Drop Down
  Quote aperrigo Quote  Post ReplyReply bullet Posted: 04 Oct 2008 at 11:11pm
You could just set up your second tower for remote connection from your 1st tower...and basically switch back and forth using your original keyboard and mouse.
That's what I would do at least.
  Quote Jail Bird Quote  Post ReplyReply bullet Posted: 04 Oct 2008 at 11:17pm
The new tower from DS will have two LAN connections ... could I connect one to the router and the other loop over to the first tower ?
lighn'ing fps
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Oct 2008 at 11:19pm
you can connect any PC as long as they are connected to the same router
Edited by DST4ME - 04 Oct 2008 at 11:20pm
This page was generated in 5.371094E-02 seconds.
