2600k not going over 16x multiplier
Post Date: 2011-03-26
jabs622 View Drop Down
  Quote jabs622 Quote  Post ReplyReply bullet Topic: 2600k not going over 16x multiplier
    Posted: 26 Mar 2011 at 1:17pm
Hi Everybody,
I have been lurking around the forums for a while now and received my new computer this week. First off it is an awesome build and I cannot be more happy with the quality DS put into it.
Chassis Model: Special Deal Hot Seller - Black OPS Assassin Edition
Expansion Bay: Internal Digital Media Card Reader (Black) (NOTE: Disables 2 Front USB Ports)
Hard Drive Set 1: Operating System: 1x (128GB Solid State (By: Corsair) (Model: Performance 3 Series CSSD-P3128GB2) (SATA 6Gbps)
Hard Drive Set 2: Multimedia\Data: 1x (2TB Hitachi/Seagate (7200 RPM) (32MB Cache)
Video Card(s): 1x NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology)
Extreme Cooling: H20: Stage 2: Corsair H70 Liquid CPU Cooler (High-Performance Edition)
CPU Boost: FREE: Overclock the processor between 3.6GHz to 3.9GHz
Please note this is my first desktop in about 8 years, I use to build my own pc's but a bit has changed and so please excuse my ignorance.
I have run into a few issues which is why I'm here, I had originally gone with the free overclock available and had my machine oc'd to 3.9 but when I received the computer my idle temps were hanging around 39C and that seemed high to me(maybe wrong). So I went ahead and set the defaults in the bios back just to see what I could get the temps down to. The temps ended up not changing but now my multiplier is stuck at 16x and will not budge even under full load with prime95 running.
Any assistance is appreciated, as noted above I have the asus p8p67 deluxe board.
Thanks!
  Quote jabs622 Quote  Post ReplyReply bullet Posted: 26 Mar 2011 at 2:41pm
I determined the problem to be the EPU, I suppose the defaults set it to Max Power Savings, I changed this to Auto and I am now at a 35x multiplier.
My question now based off what you see here are these temps normal(OK), also shouldn't I expect the multiplier to be around 38x with the Intel Turbo?
Thanks!
Regent Square View Drop Down
  Quote Regent Square Quote  Post ReplyReply bullet Posted: 26 Mar 2011 at 3:19pm
Hey dude, how did you set your power settings to auto? Was in it in bios or you downloaded a program for that?
  Quote jabs622 Quote  Post ReplyReply bullet Posted: 26 Mar 2011 at 4:29pm
I updated it in the Tools -> EPU section of the AI Suite II that comes with the Asus board, i'm sure this setting is somewhere in the bios but i'm not sure where.
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 27 Mar 2011 at 7:18pm
EPU should be disabled.  You can find it under the Ai Tweaker menu in the BIOS.
