295 Water Block
Post Date: 2009-09-15
Ace Zoot View Drop Down
  Quote Ace Zoot Quote  Post ReplyReply bullet Topic: 295 Water Block
    Posted: 15 Sep 2009 at 3:10pm
I have a Benchmark crusher with a DS water cooled CPU but the 295 is fan cooled. Unless I run the fans at 80% while playing games it gets above 80 degrees and the games act up. SO I would like to water cool the 295.  Any ideas?  Do I need to increase the reservoir size from a single slot to a double. Any help would be great.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Sep 2009 at 5:15pm
just set the fan to auto, or to 100%, if that does not work then call DS, it might be the card, to LC you can just keep the same reservoir, but that will jack up the temps on your cpu temps.
  Quote Ace Zoot Quote  Post ReplyReply bullet Posted: 15 Sep 2009 at 8:03pm
In Auto the fan speed does not increase until well above 85 degrees. So I have to set it myself to a higher speed.
So a bigger reservoir would help keep the overall temp down if I add a GPU water block?
Anyone use a block on a 295?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Sep 2009 at 8:47pm
the reservior is not what keeps things cooler, the rad and its fan is what is helping with the temps, you would need a bigger rad and fans that would go with it.
This page was generated in 3.613281E-02 seconds.
