2k build, would love input for improvement!
Post Date: 2015-01-08
sum420gt View Drop Down
  Quote sum420gt Quote  Post ReplyReply bullet Topic: 2k build, would love input for improvement!
    Posted: 08 Jan 2015 at 5:05am
Hey everyone, first i'd just like to say thanks for taking a look at my thread, i really enjoy this site and forum and ive had a lot of fun using the configurator over and over again to find just the right build.
A little background, i have built a computer before so i am tech friendly. I'm planning this build with idea to save money on my graphics card and build the best possible core system for future upgrading.
I was originally going to do a build with a 970gtx sli, or a single 980 however the 900 series seems to have literally hundreds of online posts about microstuttering, framerate drops, and other technical issues with no resolution in sight, which is why i went with a cheaper but more reliable AMD Radeon R9 280X 3GB.
I also plan on upgrading the memory, and hard-drive in the future.
$2000.
Hardcore gaming machine
Gaming
Configurator id: 1128752
System Model: SLADE
Chassis Model: Corsair Obsidian 550D
Motherboard: ASUS Z97-PRO (Intel Z97 Chipset) (Features 802.11ac Wi-Fi Connectivity)
System Memory: 8GB DDR3 1866MHz Digital Storm Certified
Performance Series (Highly Recommended) (Hand Tested)
Storage Set 1: 1x SSD (120GB Samsung 840 EVO)
Storage Set 2: - (will be upgrading to additional storage soon)
Graphics Card(s): 1x AMD Radeon R9 280X 3GB
Extreme Cooling: H20: Stage 2: Corsair H110 280mm Radiator
Liquid CPU Cooler (Extreme-Performance Edition)
Edited by sum420gt - 08 Jan 2015 at 5:53am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 08 Jan 2015 at 5:27am
Hi sum420gt....  Welcome to the forums.   Looks good but just an FYI.... the H110 or any 240/280mm rad will mount under the top, requiring the top acoustic cover to remain off.   If you picked the 550D for quiet, it still will be, but not as quiet as if a 120mm rad was mounted against the inside back wall.
No overclocking?   Of course, you can do it yourself, but just asking.
Good luck and stay in touch. Big%20Smile
  Quote sum420gt Quote  Post ReplyReply bullet Posted: 08 Jan 2015 at 5:49am
Hey bpratt, thanks for the advice! My main focus is to have the best performance possible so i dont mind a little extra noise. Plus i am a headphones gamer so fan noise isnt much a concern.
I actually picked the 550d to help mitigate the noise for powerful fans to do overclocking in the future.
Edited by sum420gt - 08 Jan 2015 at 5:50am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 08 Jan 2015 at 6:00am
My pleasure. Big%20Smile
I would, just me, get the gtx 970 over the 280x any day.    The 970 is up to 40-50% better frames with some games and a bit better power usage.     But, I haven't done much looking into the 280x lately, but do remember the web loaded with people with stuttering with the 280x also.  Maybe recent drivers, etc have changed all that.
Not knocking the 280x.  It is a strong card.  Big%20Smile
db188 View Drop Down
  Quote db188 Quote  Post ReplyReply bullet Posted: 08 Jan 2015 at 7:03pm
the 290x would be the equivalent card to the GTX 970 not the 280x.
  Quote sum420gt Quote  Post ReplyReply bullet Posted: 08 Jan 2015 at 7:11pm
So after many hours spent in forums, getting advice, and looking up reviews and benchmarks i have decided to go with the Gigabyte GeForce GTX 970 G1. Appreciate the help here guys!
