32'class Edge Lit Razor LED LCD HDTV
Post Date: 2011-12-18
Egore View Drop Down
  Quote Egore Quote  Post ReplyReply bullet Topic: 32'class Edge Lit Razor LED LCD HDTV
    Posted: 18 Dec 2011 at 5:26pm
Hellow guys I'm new to forms :) but I been reading, looking at builds for a long time. Maybe in the next 2 3 months I'll buy I pc from here but first would love to know if this tv would be any good for gaming.   Model number E320VP if it sucks I have to buy a new one I gess Ty for your time and feed back :)
  Quote Egore Quote  Post ReplyReply bullet Posted: 18 Dec 2011 at 6:36pm
For got to say what brand it is Lol Vizio gess that would help lol
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Dec 2011 at 7:20pm
If it does not support dvi or hdmi 1.4 you are stuck with cap of 30 fps which is not good.
Edited by DST4ME - 18 Dec 2011 at 7:20pm
  Quote Egore Quote  Post ReplyReply bullet Posted: 18 Dec 2011 at 8:14pm
I got the dum thing for my xbox it was on sall so i got it for cheap Cry worst thing ever speakers suck u cant hear sh*t  im sure ill end up buying a new one but wanted to spend most of my saving on a new pc here is the tech specs so what do u think i dont know what 1.4 means so maybe u can find it for me Big%20Smile
Class:32"
Viewable:31.51" diagonal
Tuner:NTSC/ATSC/QAM
Native Panel Resolution:1366 x 768 pixels
Signal Compatibility:1080i, 720P, 480P, 480i
Colors:1.06 Billion
Computer Support:1360 x 768 via HDMI, 1360 x 768, 1024 x 768, 800 x 600, 640 x 480 via RGB
Dynamic Contrast Ratio:100,000:1
Response Time:9ms
Viewable Angle:178/178 degrees (horizontal/vertical)
Pixel/Dot Pitch:0.51075mm(H) x 0.51075mm(V)
SRS TruSurround HD™:Yes
SRS TruVolume™:Yes
SRS TruSurround XT™:No
INPUTS (REAR)
HDMI with HDCP2
RF Connector for Internal Tuner1
Component Video:1 via VGA to Component Adapter
S-Video:
Computer RGB:1
Composite Video:1
USB Ports:1
Photo (JPEG):1
INPUTS (SIDE)
HDMI with HDCP
Component YPbPr plus Stereo Audio:
Composite Video:
S-Video:
Computer RGB:
USB Ports:
Music (MP3):
Video (MPEG):
Photo (JPEG):Yes
OUTPUTS (REAR)
SPDIF Digital Optical:1
Stereo Audio:
Headphones:
ADDITIONAL FEATURES
Refresh Rate:60Hz
Smooth Motion:No
Panel Type:LED - Edge Lit
Picture-in-Picture (PIP):No
Picture-outside-Picture (POP):No
Zero Bright Pixel Defect Guarantee:Yes
V-Chip:Yes
3D Comb Filter:Yes
3:2 or 2:2 Reverse Pull-down:No
ATSC with 8VSB & QAM demodulation:Yes
ATSC with MPEG-2 decoding:Yes
NTSC Video decoding via Video:Yes
Progressive Scan Video:Yes
Color Temperature:5400K, 6300K and 9300K
Color Fine Tuning:Red/Green/Blue
Speakers:Built-in 10W x 2 Speakers
Panel Lamp Life (typical):60,000 Hours
Voltage Range:120Vac at 50/60Hz
Power Consumption:58W, <1W Standby
VIZIO Remote Control:VR15
WEIGHT
Gross:18.74 lbs
Net With Stand:14.11 lbs
Without Stand:13.25 lbs
DIMENSIONS
With Stand:30.33"W x 21.55"H x 7.35"D
Without Stand:30.33"W x 21.55"H x 1.33"D
Packaging Dimensions:32.40"W x 23.81"H x 5.53"D
CERTIFICATIONSCSA, CSA-US, FCC Class B
COMPLIANCESENERGY STAR® 4.1 ATSC Spec A/65, EIA/CEA-766-A
WALL MOUNT SPECIFICATIONS
Hole Pattern:VESA standard 100 X 100mm
Screw Size:M4
Screw Length:10.0mm
Screw Pitch:1.0 mm
find
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Dec 2011 at 12:44am
Before I made my post above I looked at the pdf manual for your tv, I don't see a mention of 1.4 anywhere, normally they mention that as a pro for the product.
  Quote Egore Quote  Post ReplyReply bullet Posted: 20 Dec 2011 at 9:04pm
Ok what monitor would u recommend then I would like somthing that's some what big but not to small 400 500 price range?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Dec 2011 at 3:52pm
1. response time is a bs number, its there to fool you and does not represent the true response time of the monitor, there is no real way of truly finding what response time is, the closest to it is white to white but you don't see that, you see grey to grey or black to black cause they give small numbers to fool users but they don't mean anything, there are different methods to get these numbers also, and each will give a different number as results, therefore you can even compare one to the other, cause we don't know what method was used for which, and even if we did, still GTG or BTB don't mean anything.
2. contrast ratio is also bs number.
some good IPS panels are:
Dell UltraSharp U2410
Dell UltraSharp U2412M
Dell UltraSharp u2312
Edited by DST4ME - 21 Dec 2011 at 3:52pm
  Quote Egore Quote  Post ReplyReply bullet Posted: 21 Dec 2011 at 8:16pm
Ok I was talking to one of my friend about it he sayed no not a dell. He said they suck any reason why or just he doesn't know anything or doesn't know what he's talking about You seem smarter then him thow.
  Quote Egore Quote  Post ReplyReply bullet Posted: 24 Dec 2011 at 12:14am
R u made at me what I said?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Dec 2011 at 1:31am
Sorry been busy.
Your friend has no idea what he is talking about as far as monitors go, we don't recommend dell pcs either but these ips monitors are different, so many people have them on the forums.
This page was generated in 4.394531E-02 seconds.
