3500 Dollar Max
Post Date: 2009-11-25
Haakonas View Drop Down
  Quote Haakonas Quote  Post ReplyReply bullet Topic: 3500 Dollar Max
    Posted: 25 Nov 2009 at 11:56am
I have the opportunity to buy a new pc. Now that I have the chance to spend 3500.00 dollars with shipping I was looking at this setup. So my question is what do you all think. I am planning on purchasing this in Febraury of next year 2010.
Total Price with Instant Savings: $3,675.00
Direct Load URL: http://www.digitalstormonline.com/comploadsaved.asp?id=357078
Chassis Model: Special Deal Hot Seller - Cooler Master CM Storm Sniper
Processor: Intel Core i7 960 3.2GHz (Quad Core)
System Memory: 6GB DDR3 1866MHz Corsair Dominator DHX (High-Performance)
Video Card: 2x SLI Quad (NVIDIA GeForce GTX 295 1.792GB) (Includes PhysX Technology)
Extreme Cooling: H20: Stage 2: Asetek Liquid CPU Cooler (240mm Radiator) (High-Performance Edition)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Red) (Up to 6 Fans)
Keyboard: Lycosa Razer Gaming Keyboard
Mouse: Razer Lachesis Gaming Mouse (High-Speed Gaming Grade)
sO what do you all think?
Edited by Haakonas - 25 Nov 2009 at 12:06pm
Spent my life looking for what was and is better. I finally found it.
  Quote Haakonas Quote  Post ReplyReply bullet Posted: 25 Nov 2009 at 11:58am
Yes I do understand i went a little over my 3500 but maybe someone can help configure this better.
Thanks to all who respond.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Nov 2009 at 12:03pm
drop the 960 CPU, use the 920, that will help with the price, and have zero impact on performance.
may want to change the RAM to 1600, I don't know what timings the 1866 is, so it might be worth it, might not.
your CPU cooling, I would go with the Noctua air cooling, or get a real water cooling setup.
power supply, might want to change it to the Corsair 1000 watt, very nice power supply.
the LED fans are a bit loud without a fan controller, so I would either drop them, or add a fan controller.
Edited by justin.kerr - 25 Nov 2009 at 12:04pm
  Quote Haakonas Quote  Post ReplyReply bullet Posted: 25 Nov 2009 at 12:14pm
Wow i originally wanted an I7 975 but was not available and you are saying I should just go with a 920? I guess I was going a bit nuts. The rest i will look and get back to you.
I thank you most kind.
Edited by Haakonas - 25 Nov 2009 at 12:15pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Nov 2009 at 12:18pm
yes do the 920 for sure.
  Quote Haakonas Quote  Post ReplyReply bullet Posted: 25 Nov 2009 at 12:39pm
Do you think that by early or later next year we would need higher than a 920?
Here would be an adjustment any better?
Enhancements: Touch 2000 Aerocool Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade)
Price $3436.00
Edited by Haakonas - 25 Nov 2009 at 12:43pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Nov 2009 at 12:53pm
No, the 920 will be good for a long time.. there will be a 12 thread enthusiast chip next year called the i9, but it will not be needed for gaming for a long time.. A well overclocked 920 will be good for a while. 4-5 years.
The RAM,  going down to 1600Mhz speed will show you basically the same performance, looks like the timings are the same..
Also with the 1866 RAM,  will give you an overclock of 3.9Ghz, if they run the RAM at full speed. Not sure if they do that or not.. lol
