3rd DS machine comming soon! Please help
Post Date: 2013-10-01
Rmat56 View Drop Down
  Quote Rmat56 Quote  Post ReplyReply bullet Topic: 3rd DS machine comming soon! Please help
    Posted: 01 Oct 2013 at 10:30pm
$3000
Outstanding performance and great customer care... That's why back for a 3rd time.
Home office, gaming, photo editing, some video work, web, and did I mention gaming.
For Mom so reliability is a must.
Saved Ticket #: 876181
Chassis Model: Special Deal Hot Seller - Digital Storm ODE V3
Motherboard: ASUS Z87-EXPERT (Intel Z87 Chipset) (Features Intel Thunderbolt Technology)
System Memory: 16GB DDR3 1600MHz Corsair Dominator DHX (High-Performance)
Storage Set 1: 1x (128GB Solid State (By: Samsung) (Model: 840 Pro Series)
Storage Set 2: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition)
Graphics Card(s): 1x AMD Radeon HD 7970 3GB
Chassis Fans: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans)
Airflow Control: Strike-X AeroCool Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade)
As I mentioned earlier this will be the third DS comp for the family. First was for Mom back in Dec of 09'. This will be a replacement for her. Her old one will be passed down to one of the grandkids as it still runs great. Mom just wants something new!
Any advice would be great. It has been a while since I seriously looked at new comps. But already know it will be a DS or not at all.
Thanks for the replies in advance.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 01 Oct 2013 at 10:56pm
Sweet! A Gaming MOM!! That rocks!!
The only things I would recommend changing is the the GPU to the GTX 770 (either the 2GB or 4GB). It outperforms on most games over the 7970. Also, with the single GPU, you could use just a 750W PSU - the EVGA is a great choice as it's 100% modular so if it needs replacement, no rewiring required. Otherwise looks like a solid build. And don't forget your FREE t-shirt (or would it be hers?)!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 Oct 2013 at 3:14am
Excellant build with quality parts.
The ODE 600t case with Noctua D14 cooler means well built and reliable.
It doesn't need the upgraded fans or fan control, but if its for looks and something to tweek then go for it.
I also would go with gtx 770 and the EVGA 750 SuperNova psu for a single card but this setup works for sure.
Good luck.
