40$ Evo 860 1Tb SSD (NEED HELP)
Post Date: 2019-01-09
Nagooker View Drop Down
  Quote Nagooker Quote  Post ReplyReply bullet Topic: 40$ Evo 860 1Tb SSD (NEED HELP)
    Posted: 09 Jan 2019 at 7:19am
So I just bought a brand new 1tb 860 evo on ebay from canada for 40USD. Wish me luck fam.
Also, I have the bolt x with 470-I MOBO, i already have a m.2 ssd and a HDD, am i going to need a bracket for this ssd?
Edited by Nagooker - 09 Jan 2019 at 8:08am
  Quote Cretae Quote  Post ReplyReply bullet Posted: 11 Jan 2019 at 5:28am
Says your case is equipped for up to three 2.5" HD's. My case, a Corsair Obsidian, had plastic sliders that came out of the hard drive cage. All I had to do was screw the 860 EVO to the slider (carriage?) with screws that came with the SSD, and slide it back into the cage. Then I found power supply wiring and a free SATA cable bundled up behind the mobo. Others have said their extra hard drive bays already had wiring routed to them.
Some cases have some sort of slot/holder especially for small form factor SSD's behind the mobo.
  Quote Nagooker Quote  Post ReplyReply bullet Posted: 11 Jan 2019 at 6:12am
Im pretty sure this is the case (pun intended)
  Quote Cretae Quote  Post ReplyReply bullet Posted: 12 Jan 2019 at 1:33am
