$4000 Budget +/- 200 Need help
Post Date: 2010-05-07
Gpaint View Drop Down
  Quote Gpaint Quote  Post ReplyReply bullet Topic: $4000 Budget +/- 200 Need help
    Posted: 07 May 2010 at 10:19pm
Saved Ticket Number: 404384
Hi I have been hanging around this website for some weeks now and after surfing the forums and trying builds I think I have found where I would feel best about spending my money to get an incredible system.
I have general pc knowledge but not the most in depth, I will use my PC for gaming both MMOS and FPS and graphics work (photoshop etc) I want performance and would like to have my PC last me far longer than the disasters I've had with bigname vendors **cough DELL. I also need the PC to look fantastic. For the money spent Id like to show it off of course. Blue lights with white tubing would be my dream. (purple highlights in perfect world)
I will be buying a monitor as well. I need 1920-1200 res and 24" any suggestions? $300-400 range (This can be outside the 4000 budget)
Heres what I came up with. Whats useless and whats not? Do I need the soundblaster card if I dont use a fancy sound system? Do they all come with controls on outside for temp/fans? etc And what exactly does this case look like WITH the side panel on it...all the pics show it open only?
4308.00 I blew the budget:(
Chassis Model: Digital Storm HailStorm (Black OPS Edition)
Motherboard: !SALE: EVGA X58 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: OCZ) (Model: OCZSSD2-1SLD120G)
Hard Drive Set 2: Multimedia\Data: 1x (1TB Seagate/Hitachi/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Optical Drive 2: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology)
Sound Card: Creative Labs X-Fi Titanium Fatal1ty Professional (PCI-Express Slot Based)
H20 Tube Color:White Tubing with High-Performance Fluid (UV Lighting Reactive)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans)
Surge Shield: APC SurgeArrest Personal PER7 (7 Outlet) 120V Surge Protector
Thanks!:)
Edit: Linked wrong config
Edited by Gpaint - 07 May 2010 at 10:39pm
Intel i7 930 @4.27GHz
EVGA x58 FTW3
Hailstorm - 6GB DDR3 1600mhz
Dual Nvidia GTX 480 1.5GB
Corsair GT Force SSD (180GB) - Western Digital 1TB (64MB)
Full Sub Zero Cooling
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 07 May 2010 at 11:23pm
EVGA x3 SLI board doesn't really offer you anything the EVGA LE doesn't. Indilinx SSDs (like the one you have selected) suck, go with a 80GB or 160GB Intel SSD. How badly do you need/want the Blu-Ray player? Drop it if it isn't needed. How badly do you need/want a sound card? Drop it if it isn't needed. A single GTX 480 will max all but 2-3 games at 1920x1200 resolution, drop the second one. Upgraded case fans are very loud, that will be up to you if you can live with it, they do look very nice. Drop the surge protector, buy your own somewhere else for cheaper.
Ticket #404410, Price in cart: $3208
Hard Drive Set 1: Operating System: 1x (80GB Solid State (By: Intel) (Extreme Performance) (Model: SSDSA2MH080G2R5)
Video Card: 1x NVIDIA EVGA GeForce GTX 480 1.5GB (Includes PhysX Technology)
If you can live without the Hailstorm case and pretty white tubes of the liquid cooling, you can get the same computer and performance for $379 cheaper in the Special Deals section. Personally I like the look of the HAF 932 better than the Hailstorm and I think $379 looks sexier than white tubes, but that's just me.
Ticket #404415, Price in cart: $2829
Trim Accents: - Not Available
Enhancements: - Not Available
Chassis Mods: - Not Available
Boost Memory: - Not Available
Boost OS: - Not Available
Office: - Not Available
Benchmarking: - Not Available
Lilim
Intel Core i7 920 @4.2GHz
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 May 2010 at 2:22am
I wouldn't do the upgraded fans cause they are loud, other then that builds look great.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 08 May 2010 at 8:46am
but doesn't the LE have  horrible locked PCIe bandwidth??
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 08 May 2010 at 1:23pm
They're locked at x16/x8/x8/x4, so x16/x8 for dual SLI/CrossFire and x16/x8/x8 for triple.
But since the GTX 480 and ATI 5970 are the only two GPUs that can even start to saturate x8 bandwidth, he'll be fine. A 480 losses an average of 2% performance when limited to a x8 lane, a 5970 can lose more but 5970 suck and you shouldn't be running them in CrossFire to start with.
Lilim
sirsiddius View Drop Down
  Quote sirsiddius Quote  Post ReplyReply bullet Posted: 08 May 2010 at 2:34pm
So isn't still he losing 2% sli performance by default for choosing the LE. Much better to choose a different mobo than to chose one which is automatically nerfed to begin with.
Edited by sirsiddius - 08 May 2010 at 2:34pm
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 08 May 2010 at 4:18pm
Other boards are "nerfed" in other ways, it is a balancing act.
  • The EVGA x3 SLI can do x16/x16 or x16/x8/x8 but it costs more and you lose the ability to use bigger CPU coolers like the Noctua NH-D14.
  • The EVGA Micro is a little cheaper, can use bigger CPU coolers like the Noctua NH-D14, and can do x16/x16 but then you're out of PCIe lanes completely, no more add on cards.
  • The EVGA Classified has all the bells and whistles, PCIe lanes and fits big CPU coolers, but is very expensive.
The LE is just an ideal compromise for most people. It is basically x3 SLI board that gives up 2% SLI performance to be much cheaper and is even able to use larger CPU coolers. The Noctua NU-D14 rocks, I rarely recommend giving that up. I personally favor the Micro, I don't use any add on cards so its lack of PCIe lanes is not a problem for me, but I'm not in the majority in that regard, most would rather take that 2% SLI hit for a bunch of extra lanes.
Lilim
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 08 May 2010 at 5:31pm
for your monitor it may be alittle out of ur range... but it is great and one of the best on the market. get a dell u2410 monitor
2.5 Ghz Core duo
Nvidia 9500 gt
3 gb 1033 Mhz ram
[email protected]
  Quote Cretae Quote  Post ReplyReply bullet Posted: 08 May 2010 at 5:56pm
Actually, I'd like to have that one myself, but it's a little out of my range, too.
Here's one you might go for at ~$400.
I don't have this, but it's at the top of my list.
Coolermaster Storm Sniper
Intel Core i7 930 3.8GHz OC
EVGA X58 LE
6GB DDR3 1600Mhz Ram
750W Corsair
1TB HDD
1x ATI RadeonHD 5870 1GB
Noctua Dual 120mm
  Quote sirsiddius Quote  Post ReplyReply bullet Posted: 08 May 2010 at 6:26pm
True...True, well Gpaint does claim to have a 4000USD budget so I suppose an extra 44 bucks to upgrade to an evga sli won't mean that much to him, especially since he's already dropping huge wads of money on sli'ed gtx 480s to begin with, he might as well get the most out of his monster gpus.
BTW you know whats a great board: the asus p6x58d-e. Has a great rep, oc's brilliantly and has usb 3 and sata 3 support, and its great value for the money. This one is the board I'll be getting for my summer build.
Edited by sirsiddius - 08 May 2010 at 6:27pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 08 May 2010 at 6:38pm
Evga has two ok boards, Micro and classified.. others...
Ausus p6.....good luck, get the Gigabyte, X58a Ud3, better board, cheaper.. or step up to the X58a ud5.. twice the board of the Asus...
  Quote Gpaint Quote  Post ReplyReply bullet Posted: 08 May 2010 at 10:57pm
Thanks for the replies so far:) @dragoonseal I appreciate you showing me how and where I can lower the costs. I have trouble visualizing what Im getting when I make my configs so I tend to assume the available upgrades are practically needed to have it be a halfway decent machine.
Its a bit out of my understanding what your discussing with the motherboards but, I would just get the motherboard that wouldn't cause any performance loss. I would never be in the territory of using more than a dual GPU setup however.
So here are some further questions to help me understand for making choices.
I see many configs using the i7920+ overclock...the price diff between the 930+overclock is small...is there a reason to go with one vs the other?
If im using headphones and a simpler speaker setup is the money spent on a sound card worth it? And is it a simple process to add later on?
The area I'm having the most trouble on is the cooling options, it is easy to select options and jump that price way up. I want to be safe with my temps but I dont want a very loud machine either. If I dont have a fancy sub zero I would still have the case lit up in a color of my choice right? Oh and the front panel temp controls...how nice is this to have? Very useful or more a novelty?
So basically I like what dragoon did but cutting out the unneeded ( one GPU is good for now I agree) Just trying to learn a little more about what my machine will look like/sound like with the less expensive options. And I will be using the DELL ultra sharp 24
ty again
EVGA x58 FTW3
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 May 2010 at 12:12am
stick with 920, as pointed out the LE will give you what you need, even in dual gpu, you lose like 4 fps, which in dual gpu environment will not be noticed.
I'm not a sound expert but all sound experts say that if you use headphones, best to go with a sound card.
90% of your sound comes from gpu's fans when gpu is under load, so to LC the cpu does not save you any sound, the gpu needs to be LCed and if you want quiet then you want a particular rad and fans on them to have a quiet LC system.
for cooling on cpu go with Noctua, as I said the upgraded fans are loud, and the fan controller does not control all your fans and its temps are not accurate, thus its pointless.
go with the second build dragoonseal made, just keep in mind to make sure that 80GB is enough room for what you are doing, and drop the upgraded fans.
  Quote Gpaint Quote  Post ReplyReply bullet Posted: 11 May 2010 at 9:27pm
Ive been doing alot of research on video cards and I just cant seem to find two sites that agree but overall I seem to find more evidense that the ati 5970 is the better choice over the 480? Seems in part due to it having had more time to be updated. I know the 5970 is essentially 2 GPUS with 1gb ram. I will be a gamer on the pc i purchase from here but i will do alot of graphical work, which is better from a gaming + proffesional perspective? Eveyone here seems to always tell it how it is....
 and I was hoping to see the insight you all have in the 5970 vs 480 discussionPinch
ty
EVGA x58 FTW3
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 11 May 2010 at 10:06pm
the 5970 is  faster than the GTX 480. on average.. I can show you games where the 5970 beats the 480 badly, and others where the 480 will win, by a bit.. change the in game settings and everything changes again..
but for overall gaming experience I would get the GTX 480, and get a powerful enough power supply, so that you can run two of them down the road.
or get 2 5870's... the 5970 has had a lot of driver issues, not letting it perform as well as it should.
take the reviews with a grain of salt, most reviewers have no idea what they are doing. I was just looking at a recent review of 3 5870's overclocked running resident evil 5, 1920 x 1200 res, max settings... he got a lower score than I got with my 2 4890's.. and 1/2 of what my 5870's get..
  Quote Gpaint Quote  Post ReplyReply bullet Posted: 11 May 2010 at 10:13pm
Thanks for the fast Reply:0
Should I be concerned about the apparent noise/heat/power draw of the 480 or can that all be optimized through driver updates as times goes by? Would a LC option help lower the noise by much?
EVGA x58 FTW3
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 May 2010 at 5:06pm
another vote for 2 x 480/5870 instead of 4970.
noise is gonna be an issue with any gpu under load. LC will eliminate this issue, and it will take care of heat issue also, however lately I have seen many people with sli 480 on air and they say that their temps are much lower then what was reported by the reviews, your room temp will play big part in all that also.
I would go with one 4805870 and as justin said, get a big enough psu, so that if I need to add another down the road, my psu can handle it, for cf 5870 a corsair 1000w will do and for sli 480 the 1250 enermax is great also.
