$450 less for same build
Post Date: 2011-09-26
Trench View Drop Down
  Quote Trench Quote  Post ReplyReply bullet Topic: $450 less for same build
    Posted: 26 Sep 2011 at 8:56pm
The only difference is a CPU fan and slightly different PSU model. Not wanting to troll, but...damn.
Here is the info:
[digital storm]
Chassis Model: Black OPS Assassin Edition
Processor: Intel Core i7 2600K 3.40GHz
Motherboard: ASUS P8P67 Deluxe (Intel P67 Chipset)
Video Card: 1x NVIDIA GeForce GTX 580 1.5GB (Overclocked EVGA
Edition)
System Memory: 8GB DDR3 1600MHz Corsair Dominator DHX
Power Supply: 750W Corsair HX
250GB Solid State Intel 510 Series
Extreme Cooling: AIR: Stage 2: Noctua NH-D14 Extreme Performance
Total Price with Instant Savings: $2,909.00
___________________________________________________________________
[removed]
CASE:SilverStone FT02 Fortress Series Full Tower All Aluminum Body Case
CPU:Intel® Core™ i7-2600K 3.40 GHz
MOTHERBOARD: Asus P8Z68 Deluxe Intel Z68 ATX
VIDEO:NVIDIA GeForce GTX 580 1.5GB (EVGA Superclocked)
MEMORY:8GB (2GBx4) DDR3/1600MHz Dual Channel Memory Module (Corsair Dominator)
POWERSUPPLY:850 Watts - Corsair Professional Series CMPSU-AX850 80 Plus Gold
HDD:250 GB Intel 510 Solid State Disk
FAN: Thermaltake FRIO Overclocking Cooler Fan (CLP0564) [+20]
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
PRICE:(+2462)
Edited by Alex - 26 Sep 2011 at 11:30pm
Chi-TownTx View Drop Down
  Quote Chi-TownTx Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 9:06pm
Ehh ya but it's [removed]. Always a 50/50 build with them. Either you get lucky and everything works fine on your comp or you get screwed if it doesn't.
Let's say something ends up being wrong with it. For warranty coverage etc you gotta send the whole thing back. If you look at reviews no one has ever had their comp repaired by them on the first send back. So you end up sending it back a second time all while your no hassle 30 day money back guarantee is still ticking.
During all this shipping time it still counts towards the money back guarantee. So after getting your comp back a second time and it's still not working all you can do is keep sending it back to them over and over again hoping that one day they get it right. However you can never get a refund even if you send it in 6 times for repair. Check the forums and you will find tons of stuff like this in review info.
I am sure [removed] has many computers that go out the door without a hitch. However it's the risk of all the bad things that happen if it doesn't go well that has some people willing to pay a bit extra.
You get what you pay for.
Edited by Alex - 26 Sep 2011 at 11:31pm
  Quote Trench Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 9:21pm
I hear you. A good build and zero problems is of utmost importance to me. But $450 for that is huge.
  Quote Chi-TownTx Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 9:46pm
Just a side note but did you see the ode level 2 build.
Not exactly the same as yours but pretty close. Also comes in at 1,999 dollars so cheaper than the other two you listed.
http://www.digitalstormonline.com/comploadode.asp?id=597328
Edited by Chi-TownTx - 26 Sep 2011 at 9:47pm
Dranzogger View Drop Down
  Quote Dranzogger Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 11:03pm
A different fan, mobo, and PSU can make a decent difference in gaming, plus with DS you get epic costumer support and a company that cares about you getting a great rig, not just getting your money.
  Quote Trench Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 11:19pm
If a friend said he would configure your system for $XXX, and another friend -- with maybe a better rep -- said he would do the same thing for $450 more, which would you choose?
I can see paying more for the lack of heartache, but $450?
I e-mailed Digital Storm with my config and with this specific one-on-one comparison and a request that they cut a break on the price. We'll see what they say.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 11:20pm
Not the same at all, your cpu cooler on [removed] sucks, what is the brand of the gpu? what is the oc at with cbp? as the others mentioned the customer support is great with DS.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 11:24pm
With all due respect you also don't know what you are doing, actually this will cost $200 more then your cbp config and $200 less then your ds config, and will be twice as powerful as the config from cbp.
Here you go Ticket# 600465 --- $2,699 (To see this build click here)
better bigger case with better airflow, faster ssd, better psu, higher oc, dual sli that will eat single 580, and a proper cpu cooler no thermaltake bs here.
Edited by DST4ME - 26 Sep 2011 at 11:26pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 11:26pm
if you tell us what res you gonna be gaming at, we can help you get what you need, I bet you nobody did that for you at cbp.
where did you get the idea that cpb is reputable? I would not buy one of their pcs with your money, lol, let along my own, the only thing they have a rep for is building bs systems with use parts.
Edited by DST4ME - 26 Sep 2011 at 11:28pm
  Quote Trench Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 11:29pm
I take you point on the CPU cooler...I'm not an expert.
Was also troubled by lack of mention on brand of CPU.
Now tell me about $2450 vs. $2900. For that diff. I want included that Jennifer "Luv" Hewitt put her boobs in my face for three minutes. Or something.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 11:31pm
I told you in my previous post, your configs are wrong to being with, I build you a config for $200 or so more then cbp but twice as powerful.
  Quote Alex Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 11:37pm
@Trench,
Thank you for your interest in Digital Storm. I do see that you really would love a system from us, and I see that the price difference compared to a different company appears to be much less.
I do wish to express that, our main focus is taking our time to build each and every system with care, test them as extensively as possible, package them as carefully as possible, and provide the best customer service and support. All of these extra factors are what adds into the cost of our systems. The extra cost in labor for personalizing each build with a single technician versus an assembly line, the time, labor, and electricity to test the systems for extensive periods, and all of the other overhead to ensure we do the best we can does come at a price.
We did launch our pre-built ODE line of gaming pcs which are designed to offer very competitive pricing. If you would love to be a Digital Storm customer, and take advantage of all of the great benefits of buying a Digital Storm PC, I would definitely recommend having a look at our ODE gaming line. They are part of our "Special|Ops" brand under gaming desktops.
I hope this helps! If you have any other questions, feel free to contact me directly: [email protected]
Big%20Smile
  Quote Trench Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 11:49pm
We were posting at the same time...
I've seen your recommendations several times here, and I've taken them to heart.
1) I don't want to mess with driver issues on SLI. I want to minimize opportunity for problems.
2) I think my choice of HD is valid -- one HD, less opp. for error.
I ain't a builder like you guys. I'm an newspaper editor who works from home and likes gaming.
3) "Power Supply: 1050W Corsair Pro Silver 1050HX" -- many advise as overkill.
Anyway, the issue here is the $450 premium for peace of mind. Guess I need to sleep on it.
  Quote Trench Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 11:51pm
I'm looking at the Acer GD235HZbid Widescreen 23.6".
  Quote Trench Quote  Post ReplyReply bullet Posted: 26 Sep 2011 at 11:55pm
Sorry, I see that I'm hitting "reply" rather than "quote."
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Sep 2011 at 12:12am
your choice of ssd is not good cause that is not a great ssd nor is it the fastest, the 320 is more reliable and at 4k speeds which is most of our use, the 320 is faster and 320 is the only ssd that has a 5 year warranty.
also I don't agree that one hdd = less problems, sure 2 things means now chances of 2 things going wrong, but you also stand to lose all your data if the drive goes bad since everything is one drive.
as for driver issues with sli, there are some but not a lot however is this pc for gaming? if its for gaming and you want to run the games at the best settings, you need sli 570 to that at your res.
I also don't agree with 1050hx being overkill, cause you need sli for gaming at best setting and for that you need the 1050hx, but if you want a single system then the 850w is also overkill.
just judging by what you are saying its obvious to me you have been getting some bad info.
I can tell you right now, you are wasting money on ft02, 580, 850w psu and the mobo, if all you want is a single gpu system.
that $450 you keep bringing up, DS has a better cpu cooler thus it costs more, so that is part of the $450, so lets say $400, for that $400 you get lot more faster pc, what is the oc that cbp does on that system? cause I can assure you that DS's system will be much much much faster then the cbp, so take another $100 off for it being a faster pc, now we are down to $300, I'm not sure why you think proper customer svc is not worth more money, but if you go with cpb, then next time you buy a pc you will pay extra attention to customer svc, cbp will teach a good lesson about how important customer svc is, once you deal with their crappy customer svc, you will realize how important it is.
but look, here is a DS config that is better then the cpb you posted for less, so what $300? :
Here you go Ticket# 600473 --- $2,408 (To see this build click here)
Video Card: 1x NVIDIA GeForce GTX 580 1.5GB (Includes PhysX) (Overclocked EVGA Edition)
now I would never recommend this build to you cause its all over the place and waste of your money, just like your 2 configs.
once you let me know what the use of the pc is and if its for gaming you want the best settings or not (this means sli) then I can give a config that will give you the most performance for your money. I can assure you that other then my sli config, non of the other configs are worth your money in performance.
Edited by DST4ME - 27 Sep 2011 at 12:27am
  Quote Trench Quote  Post ReplyReply bullet Posted: 27 Sep 2011 at 12:33am
For gaming.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Sep 2011 at 12:34am
Ok so for gaming, now do you want the best settings at your res which means sli, or you want to stick with one gpu setup?
  Quote Trench Quote  Post ReplyReply bullet Posted: 27 Sep 2011 at 12:35am
One GPU.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Sep 2011 at 1:07am
Here you go Ticket# 600487 --- $2,148 (To see this build click here)
Motherboard: ASUS P8Z68-V PRO (Intel Z68 Chipset) (Features Intel Quick Sync Technology)
Video Card: 1x NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology) (EVGA Edition)
now do you know what ocing is?
also if believe I know what I'm talking about, then I like for you to ask yourself one thing, "why didn't DST4ME go and buy his pc from cbp or any other builder?" and let me give you this bit of info, as particular I am about every hardware on a pc and how it is and how well it performs and etc, I'm more particular when it comes to handing my good earned money over to any company, and because of that I did my research before I ended up here at DS, and by research I don't mean I read website reviews online, I mean I read everything I can on the net, websites/forums/friends I trust and etc, I'm so particular, that I first became a member here and hanged around for the first year before I ordered my pc just to be sure I'm handing my money to the right people(look at my avatar, I joined apr 2008, but didn't buy till august of 2009), so ask yourself how is it that somebody like me, gave their money (more of it) to DS then not a cheaper builder?
Edited by DST4ME - 27 Sep 2011 at 1:30am
