480 GTX Fan Speed Adjustments
Post Date: 2010-07-24
JJJJ_Shabadoo View Drop Down
  Quote JJJJ_Shabadoo Quote  Post ReplyReply bullet Topic: 480 GTX Fan Speed Adjustments
    Posted: 24 Jul 2010 at 7:23pm
So I'd like to tweak the default fan speeds of my GTX 480. I know I can use Afterburner (which I am currently doing), but is there any way to change the default fan speed at a given temperature on the card itself so I won't have to have Afterburner running?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 24 Jul 2010 at 8:05pm
yes, just mod the fan profile on the GPU BIOS
  Quote JJJJ_Shabadoo Quote  Post ReplyReply bullet Posted: 24 Jul 2010 at 8:21pm
Sounds simple enough!
Ughh...how do I do that?
Liq View Drop Down
  Quote Liq Quote  Post ReplyReply bullet Posted: 25 Jul 2010 at 10:26am
 why wouldn't you just use Afterburner, and have it start up with Windows? It just seems the simplest way of doing it.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 01 Aug 2010 at 7:05pm
yea afterburner is pretty simple, and will be a good thing to use for fine adjustments even if you want to set it in the bios after you are sure of your decision
