680 temps
Post Date: 2012-04-04
jmo195 View Drop Down
  Quote jmo195 Quote  Post ReplyReply bullet Topic: 680 temps
    Posted: 04 Apr 2012 at 9:36pm
Been running SLI 680's for the past two days and with SWTOR I'm averaging around 66-73 degrees Celsius. Anyone else running SLI 680's know their average temps?
  Quote FrankW Quote  Post ReplyReply bullet Posted: 10 Apr 2012 at 2:27pm
Hi jmo195,
I am not running 680's but what is your setup? It makes a difference on what case you have and what cooling you have. For instance, your GPUs would run hotter in a Hailstorm case if they weren't LC. Maybe we can do something to bring them down just a bit.
Becks View Drop Down
  Quote Becks Quote  Post ReplyReply bullet Posted: 12 Apr 2012 at 8:10am
Frank is correct jmo195. Without knowing the paticulars of your set-up it is impossible for anyone to give you good recommendations for a solution.It could be as simple as not having enough positive air-flow to exhaust the heat being generated. As an owner of a 680GTX I can attest to the fact that they do run pretty cool.
Relationships Are Like Sharks. They Either Move Forward, or Die.
  Quote Alex Quote  Post ReplyReply bullet Posted: 12 Apr 2012 at 3:59pm
Those temps are perfectly in-line and good.
This page was generated in 5.761719E-02 seconds.
