780i Noise Issue
Post Date: 2008-07-03
Nickdapimp View Drop Down
  Quote Nickdapimp Quote  Post ReplyReply bullet Topic: 780i Noise Issue
    Posted: 03 Jul 2008 at 7:41pm
I just got my PC today ( the one in my sig ) and it's wonderful, I got liquid cooling and NO NOISE AT ALL only the power supply is the noisey one...but...theirs this sound coming from the computer and I think its the 780i i dunno if you had AOL but when you opened AOL like 2-3 years ago it made noises in your computer and thats like the one happening to me, and its like scatter noises...please help?
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 03 Jul 2008 at 7:46pm
Worth a shot checking out the northbridge fan. If its not that it might be a quirky capacitor.
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
4GB OCZ Reaper 1800Mhz
250-80-300GB VR HD
Logitech Z-2300 2.1 Speakers
Asus Xonar 7.1
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 03 Jul 2008 at 11:10pm
If you mean dialup type squealing tones, that's probably a capacitor.
  Quote Nickdapimp Quote  Post ReplyReply bullet Posted: 04 Jul 2008 at 7:14am
Yeah it's the dail up noises
Edited by Nickdapimp - 04 Jul 2008 at 7:23am
  Quote Nickdapimp Quote  Post ReplyReply bullet Posted: 04 Jul 2008 at 7:22am
if it's the capacitor, is it a problem? cause it's loud and does it like all the time
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 04 Jul 2008 at 10:06am
There may not be anything technically "wrong" with the component with the noisy capacitor, but if that is the source of the noise, it's also unlikely to stop. You should contact DSO and explain the issue. See what they think the source of your noise is (perhaps they are aware of another cause for this that does not include the need for a part replacement). If it is a capacitor, you may need to have the part swapped out in order to be free of this noise.
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 04 Jul 2008 at 11:20am
I know Puget computers will replace your mobo if its doing that. dunno about DS
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
250-80-300GB VR HD
Asus Xonar 7.1
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 04 Jul 2008 at 2:09pm
It would prolly be helpful to isolate the region that the noise is coming from prior to calling DSO. If it's a noisy cap, it could be on a graphics card or other component as well. Make sure it's not your optical drive as they are prolly one of the cheapest parts in your case. If you have access to a db meter, that will aid in locating the noise source once you determine the approximate frequency. Or just wing it and use your ears... it could be resonant frequencies from one of your HDD as well. Make sure all connections are secure. Still, the velociraptor and raptors have some interesting resonances...
