850si case question
Post Date: 2008-07-31
jimbos123 View Drop Down
  Quote jimbos123 Quote  Post ReplyReply bullet Topic: 850si case question
    Posted: 31 Jul 2008 at 1:40am
Hi I have a question about the case I ordered in my order. The 850si case is also called the coolmaster 830 stacker right? If they are not the same what are the differences between them? Also is the 850si case easy to open up without the use of screws? I looked online at http://www.newegg.com/Product/Product.aspx?Item=N82E16811119103  and there was a fan door of some type in the pictures, but I am not sure how that works. Does my 850si case come with the fan doors? I wanted to know so I can check for loose wiring etc, but opening up a case is intimidating. The 850 case has 9 fans in it too right? I hope it is easy to open?
Edited by jimbos123 - 31 Jul 2008 at 2:02am
BIGdumbANIMAL View Drop Down
  Quote BIGdumbANIMAL Quote  Post ReplyReply bullet Posted: 31 Jul 2008 at 3:55am
I have ordered the 850 as well, I will not receive in till next Tuesday, But there is a post on this forum of a review with a 850. the door on the side does open not sure how, but it does open to show the fan doors and on the right sidde of the pic. you can see two little metal tabs that im sure you just pull back to open. The address you posted is a spitin image of the 850. I was going to go with the aztec or 750 but I looked at the specs and seen that the 850 comes with 4 ports. two on top and two in front I believe. plus the airflow and upgrade scored rather high. With the stage 3 cooling I ordered I do not know how many fans are installed 7 - 9 sound right though. If nobody has answered all your questions by then, which I doubt, I will give you the lowdown when "Beula" gets here.
Edited by BIGdumbANIMAL - 31 Jul 2008 at 4:09am
Your only young once, But you can be immature for ever.
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 31 Jul 2008 at 11:54am
the actual fan count is:
1x back exhaust
2x front intake
4x side intake
2x top exhaust
Edited by skyR - 31 Jul 2008 at 11:55am
MrNanite View Drop Down
  Quote MrNanite Quote  Post ReplyReply bullet Posted: 31 Jul 2008 at 12:14pm
What?  No streamers on the exhaust fans?  Big%20smile  LOL
This page was generated in 6.835938E-02 seconds.
