950i with 650Si case - please review
Post Date: 2008-05-18
shalevy View Drop Down
  Quote shalevy Quote  Post ReplyReply bullet Topic: 950i with 650Si case - please review
    Posted: 18 May 2008 at 5:15am
Hi,
I'm going to buy the following configuration with 1 exception. I actually already have the QX9770 processor, so I'm going to select the cheapest processot when I actually place the order. I wanted to make sure this configuration will work for me after I place my own processor. Also, how easy would it be to replace the processot with the air cooling stage 2? and would that create any difficulties to the warranty?
Here is the configuration:
Case: Digital Storm 650Si (Black Anodized Aluminum Finish)
Power Supply: 550W Corsair HX (Dual SLI Compatible) (Silent Edition)
Processor: Intel Core 2 Quad QX9770 Extreme 3.20GHz (1600MHz FSB) (12MB Cache)
Motherboard: nVidia 790i Ultra Core 2 Quad (nForce 790i Ultra  SLI) (DDR3 Only)
Memory: 2GB DDR3 Corsair at 1333MHz
Hard Drive 2: - I will probably add another one later on
Video Card: nVidia GeForce 9800GTX 512MB
Sound Card: Motherboard Multi-Channel High Definition Audio
Cooling: Air Cooled Stage 2 (Silent Artic Cooling Heat-sink Upgrade (Copper Heatpipes)
Case Lighting: - No Thanks
Overclock Processor: - No Thanks, Please do not overclock my processor
Windows OS: Microsoft Windows Vista Home Premium
Thanks,
Shay
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 18 May 2008 at 7:26am
You have to uninstall the heatsink and remove the permal paste from the heatsink with 99% alcohol and a lint free cloth. Then remove the processor and place your own in the socket. Re-apply thermal paste and install the heatsink. It's the hardest part of an computer installation IMO so if you've never done it, it might be hard for you.
  Quote shalevy Quote  Post ReplyReply bullet Posted: 18 May 2008 at 7:46am
Thanks! I actually did this in the past (without cleaning the thermal the heatsink) and it works perfect. Certainly cleaning it is a good tip.
I'm concerned about using the 650Si case with the QX9770 processor and about digital storm warrenty...
Shay
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 18 May 2008 at 9:53am
personally i would talk to a rep about mailing them your chip (putting it on your order with the price removed) and just putting the order together as if your chip was the one they got out of a box.
as far as the case, if you link your build it would be easier look over
  Quote shalevy Quote  Post ReplyReply bullet Posted: 20 May 2008 at 1:20am
Hi,
CR4ZYT0M View Drop Down
  Quote CR4ZYT0M Quote  Post ReplyReply bullet Posted: 21 May 2008 at 6:07pm
With such a small case there might be some cooling issues, but I'm not really sure if there will be.
And yes, I would mail them the chip and have them install it, professionally done and afaik it would be covered by the warranty. I would call DSO and talk to someone about that if you can.
850Si Case
Intel Core 2 Quad Q9450 2.66GHz
4GB DDR2 Corsair at 1066MHz Dominator DHX
X-Fi XtremeGamer Sound Card
Air Cooled Stage 3
Graphic version coming soon
