950si case noise level
Post Date: 2010-03-03
maxage View Drop Down
  Quote maxage Quote  Post ReplyReply bullet Topic: 950si case noise level
    Posted: 03 Mar 2010 at 12:12pm
Hi all,
I like the 950si case but read in a computer shopper review that it was loud. Does anyone have this case that can comment? The article is almost a year old.
http://computershopper.com/desktops/reviews/digital-storm-950si
Thanx,
Maxage
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 03 Mar 2010 at 2:42pm
the case is never louder then the gpu's fans, 90% of your noise will come from the gpu's fans when gpu is under load.
don't believe all these reviews you read on the net, almost all of them has some stupid thing in them that is wrong.
also that review is from last year and it has different parts.
in short the case is never the main source of noise or even lot of noise, be it 950si or haf, at best they have very little noise.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 03 Mar 2010 at 2:43pm
true unless they put "upgraded" fans in that build, then I doubt you could here the gpus over them loud mothers.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 03 Mar 2010 at 3:00pm
ya the upgraded fans are loud.
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 03 Mar 2010 at 4:38pm
DS needs to supply some sort of fan controller option. The RV01 I have myself is unbelievably quiet, if I use a manual controller to silence the annoyingly loud 80mm memory fans. The Corsair Dominator airflow fans are ridiculously loud. Zalman's aren't too quiet themselves, either, depite being labeled "quiet" fan.  I swapped them out for quiet, 9-bladed fans from Silverstone themselves.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 03 Mar 2010 at 4:41pm
they do have a fan controller option. Embarrassed
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 03 Mar 2010 at 9:29pm
They're touch controllers (room for error XP) and they have temp controls.... I don't like having leads all over my system xD Anyways, it won't work with the Raven case, which I have, specifically because the front 5.25 stealth door is designed to be closed, not open.
I meant like the thumb turny controllers Ouch
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 04 Apr 2010 at 9:05pm
I've had an air cooled Silverstone TJ09 (aka DS 950si) for a few years. It seems to me that the only feature of the case that might make it loud is that half the top is open grillwork. So most of the noise in the case is going to get out. The real answer to your question is, it's as loud as the components in the case.
I do love my TJ09, btw.
