950si Case top fan airflow direction
Post Date: 2009-07-03
angler View Drop Down
  Quote angler Quote  Post ReplyReply bullet Topic: 950si Case top fan airflow direction
    Posted: 03 Jul 2009 at 7:09pm
Howdy! Had my PC for a bit now and am loving it. Got my fans running quiet like I like them and only have to turn up my GPU fan (off of auto) for a handful of games that run hot. My question is that in the DS pictures for the 950si case the top vent are designed for airflow into the case. That is the direction I have my my two 120mm's blowing. I just bought an Antec 300 case for a PC I built my wife and it shows the top vent fans are suppossed to blow out. I thought I had read on a forum here that someone had done temperature test with the fans blowing both ways and they didn't see a difference but I could not find that post. Has anyone experimented with this? I have the regular built in case fan, a 120mm exhaust, a 120mm over my hard drives, and two 120 mm fans blowing in on top. Any feedback is appreciated.
  Quote Alex Quote  Post ReplyReply bullet Posted: 03 Jul 2009 at 7:16pm
Is your system liquid cooled out of curiosity?
  Quote angler Quote  Post ReplyReply bullet Posted: 03 Jul 2009 at 7:19pm
No sir - i really should put my info in the signature line... sorry. I have the V8 cooler on my CPU and the GTX 295 for graphics. Also have all Zalman fans except for the stock case fans.
Zurginator View Drop Down
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 03 Jul 2009 at 7:28pm
I always say put top as exhaust, because hot air naturally rises.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 03 Jul 2009 at 9:34pm
should not make a difference if you have a good powerful exhaust fan you can have the rest blowing in, moving hot air out is all great but but if you hitting the part with cool air, the temps should be better.
This page was generated in 4.589844E-02 seconds.
