A few questions on an ODE custom build.
Post Date: 2013-10-27
Badact View Drop Down
  Quote Badact Quote  Post ReplyReply bullet Topic: A few questions on an ODE custom build.
    Posted: 27 Oct 2013 at 12:58pm
This computer will be use mainly for gaming, WoW, RIFT, Diablo III ect. ect..
My budget is $4000, give or take a $100.
my Config number is 883869.
Chassis Model: Special Deal Hot Seller - Digital Storm ODE V3
Motherboard: ASUS Z87-EXPERT (Intel Z87 Chipset) (Features Intel Thunderbolt Technology)
Expansion Bay: Internal Digital Media Card Reader (Black)
Optical Drive: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST)
Storage Set 1: 1x (240GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps)
Storage Set 2: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition)
Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 780 3GB (Includes PhysX)
Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans)
Airflow Control: - No Thanks
Boost OS: Yes, Disable and tweak all of the non-crucial services on the operating system
Windows OS: Microsoft Windows 8 (64-Bit Edition)
Display: Asus 24 inch 248 Series (Widescreen) (Black) (2ms Response Time) (LED Backlight)
Keyboard: Razer Nostromo Gaming Keypad
Portable Gaming: - No Thanks
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Extra Large) <b></b>
Question 1. Should I keep the upgraded fans or are the case fans ok?
Question 2. Should I go back to the water cooling setup they had?
Question 3. I might be able to upgrade to the hydrolux lighting or just to a single color, any ideas?
Question 4. Anyone use the Razer Nostromo gaming keypad, if so how do you like it.
Question 5. Should I keep the 780's in SLI or just go for the Titan as a single card?
Any other suggestions are hopeful.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 27 Oct 2013 at 2:02pm
Hi Badact....Welcome to the forums.    You put together an excellent build. If you stay with ODE 600t case then drop the fan upgrade. Not really any place to put them with the very good 200mm front and top fans.
I would suggest going with the HafX 942 case. It is the best in quality and cooling. It's side 200mm fan will feed lots of fresh air to your cards.   Don't get me wrong.....the ODE will also work so your choice.
If your only gaming on single monitor then you could save $500 and go with sli gtx 770 4 gb vram although 2gb is all needed for most games but if in the budget, why not. Sli 780 is more than needed. If you want to stay single card because of sli issues with some games then try a single 780 for now. Titan is lots more money for maybe a 10% gain.
The Noctua cooler is the best.   Very reliable, quiet and just works for years without worrying about anything.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 27 Oct 2013 at 3:00pm
Only 2 major things I would change - Samsung 840Pro SSD (instead of Corsair) and single GTX 780 (or Titan if you just wanna spend $$). You could also add the Hydrolux cooling/lighting controller as well. No need for the OS tweaks. Fans included with the ODE are already good enough (there might be space for an extra fan that you could have DS add for you). The Noctura is fine - equally as good as a closed loop liquid cooler and twice as reliable. If you wanna go water cooling, custom is the only option to give you better performance than the Noctura. But that'll set you back an additional $611 (CPU), $787 (CPU + Chipset) or $1086 (CPU + Chipset + x1 GPU). bp22 also mentioned a good upgrade with the HAF-X case as well.
884417 $3320
  Quote Badact Quote  Post ReplyReply bullet Posted: 27 Oct 2013 at 4:40pm
Ok seems everyone is saying SLI not really needed. I might be going with 2 monitors on this machine 1 for gaming and 1 for the internet and other stuff I might have up at the time. Will a single video card still be ok? If so I have redone my build as so. 884445, EDIT: now its 884468. Same as below basicly just went back to a single 780 but went with the ACX OC one, and added a sound card, and another HDD.
Storage Set 1: 1x (256GB Solid State (By: Samsung) (Model: 840 Pro Series)
Graphics Card(s): 1x NVIDIA GeForce GTX TITAN 6GB (EVGA Superclocked Edition)
Internal Lighting: Digital Storm HydroLux RGB LED Lighting System (Requires HydroLux Control Board & Software)
Airflow Control: Digital Storm HydroLux Thermal Management Control Board & Software
Speakers: Corsair SP2500 High-power 2.1 System (Includes Subwoofer) (CA-SP211NA)
Thank you all for the help so far.
Edited by Badact - 27 Oct 2013 at 6:10pm
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 27 Oct 2013 at 11:13pm
Looks like a good build from here!!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 28 Oct 2013 at 3:35am
Go for it.
This page was generated in 5.664063E-02 seconds.
