A little config help
Post Date: 2009-03-21
ectoid View Drop Down
  Quote ectoid Quote  Post ReplyReply bullet Topic: A little config help
    Posted: 21 Mar 2009 at 2:50pm
Hello all, I'm in need of some assistance. I am a Marine, currently in the Middle East, and as such I am kind of out of the loop with computer components. I'm looking to order a new system within the next week or so, so that it MIGHT possibly arrive around the same time I get back stateside. I was wondering if I could get opinions and suggestions on the following configuration. I mainly play WoW, but I would like to have the capability to play most any games that come around in decent settings. Since i play WoW mainly, the 295GTX isn't something I really want, since I would have to disable SLI and run it as a beefy 260.
I have a 26" 1080p LCD Tv that I plan on using as a stand-in until I purchase a monitor(I'd prefer to see the monitor in person). I think I'll be shopping for a 22" screen.
Liquid cooling isn't a necessity, but I've always wanted it, and figured it would help with the overclock on the processor. If I did go this route with the LC, how difficult would upgrading the processor be in the future? The water block should disconnect, without having to drain the system and such, correct?
Thank you in advance for any and all help.
Ticket Number: 261827
System Memory: 3GB DDR3 1333MHz Mushkin (Highly Recommended) (Digital Storm Certified)
Card Reader: - No Thanks
Video Card: 1x NVIDIA GeForce GTX 285 1GB (Includes PhysX Technology)
Liquid Color:Green: Non-conductive High-Performance Fluid (Requires H20: Stage 3 Cooling Package)
LCD Display: - No Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Mar 2009 at 2:55pm
thank you for your service
system looks great, but why didn't you pick 6GB of ram?
  Quote ectoid Quote  Post ReplyReply bullet Posted: 21 Mar 2009 at 3:08pm
I went with 3gb over 6gb to cut costs, with the intent to upgrade in the future. Are the advantages of 6gb that obvious that it would best to suck it up and go with 6gb from the start?
tman5890 View Drop Down
  Quote tman5890 Quote  Post ReplyReply bullet Posted: 21 Mar 2009 at 3:16pm
I went with 3gb too and I am planning to upgrade to 6gb in a month+.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Mar 2009 at 3:59pm
No you have done the right thing, save up money for a couple of month then upgrade the ram
Ok then I was just making sure you were going to upgrade later. Your system looks great, I wouldn't change a thing.
