A little help
Post Date: 2010-08-19
runner_for_no_reason View Drop Down
  Quote runner_for_no_reason Quote  Post ReplyReply bullet Topic: A little help
    Posted: 19 Aug 2010 at 11:46am
I'm in the market for a new desktop computer. I'm not a big gamer, but I'll play every now and then. I rarely play online. I'm trying to get a computer that is fast and will not be completely obsolete in 2 years. I would like to be able to play games occasionally, but mostly the system will be used for videos, music, word processing, CAD, FEA, and sometimes all of those things at once. I'd like to get a 5 year lifespan (at least) out of my computer, and I plan to upgrade slowly along the way. Also, I've heard the customer service is great here, but I would like to not have to use customer service, if you know what I mean. Maybe I shouldn't be looking at a gaming computer website, but I like the fact that I can customize the computer, the computers are easy to upgrade, and I've had bad experiences with desktops from big corporations.
My biggest question is which processor I should go for. Should I get the AMD six-core and save a lot of money, or go for an intel i7 930 or something like that since it outperforms AMD. For my needs would I even notice a difference? Thanks for the help.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 19 Aug 2010 at 11:48am
well that depends
check out the buying posting guide so you can help us help you Strong
  Quote runner_for_no_reason Quote  Post ReplyReply bullet Posted: 20 Aug 2010 at 1:13pm
Budget: $1500 max (cheaper is better)
I don't need any peripherals
A little bit of gaming, mostly music, vidoes, CAD, and FEA, usually all at the same time. I want a computer that is fast and will not be obsolete in 3 years.
plenty of storage for pictures and music
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Aug 2010 at 10:45pm
tough bill to fit for 1500, check this out
if by "plenty of storage" you meant 500gb and not 1tb, you could shave off another $50
  Quote runner_for_no_reason Quote  Post ReplyReply bullet Posted: 21 Aug 2010 at 11:13am
What about going for an AMD processor?
Ch3ssplay3r View Drop Down
  Quote Ch3ssplay3r Quote  Post ReplyReply bullet Posted: 21 Aug 2010 at 12:16pm
Eh, Theres nothing wrong with AMD processors, but they aren't great. They don't overclock nearly as well as intel, and don't have intel's hyperthreading. Cheaper? definitely.
Here's some benchmarks between Amd's phenom II quad cores, and the i7-920, both overclocked. I realize the processor in that build is the i7-860, but they overclock and perform very similarly.
http://www.tomshardware.com/reviews/overclock-phenom-ii,2119-7.html
http://www.tomshardware.com/reviews/overclock-phenom-ii,2119-8.html
I would recommend !enders build.
  Quote runner_for_no_reason Quote  Post ReplyReply bullet Posted: 22 Aug 2010 at 11:11pm
If I bump my budget up to $2000 what would you change to the suggested configuration. What kind of life span (before the computer is completely obsolete) do you think I would get?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 22 Aug 2010 at 11:20pm
http://www.digitalstormonline.com/comploadsaved.asp?id=434826%20
so hard to tell these days but i would guess around 3 years, could be more, just depends on your preferences for video quality and stuff
  Quote runner_for_no_reason Quote  Post ReplyReply bullet Posted: 23 Aug 2010 at 11:22am
One more thing, I just got a 23 inch with a 2048 x 1152 resolution. I'm assuming that the single GPU specified in the last configuration you sent is sufficient, but I just wanted to check.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 23 Aug 2010 at 11:36am
a 480 can handle that res
  Quote runner_for_no_reason Quote  Post ReplyReply bullet Posted: 23 Aug 2010 at 12:38pm
Would you recommend a solid state drive? If so should I have a solid state drive for my "Hard Drive Set 1" and a hard drive for my "Hard Drive Set 2"?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 23 Aug 2010 at 1:00pm
definitely set one, as far as if you want one, thats your call. at 2k youre right at the line to fit in a 40gb ssd, so based on what the guide says, if you feel you would use it, go for it
