A newbie question: help please
Post Date: 2009-02-16
pascal333 View Drop Down
  Quote pascal333 Quote  Post ReplyReply bullet Topic: A newbie question: help please
    Posted: 16 Feb 2009 at 8:52pm
Please see if you have any suggestions for this configuration. In particular, is the temperature display and fan control worth the $ with the Zalman fans? I am thinking I might want it to control noise but I am flying blind.
Thanks ahead of time...
http://www.digitalstormonline.com/forums/smileys/smiley4.gif
Chassis Model: Digital Storm 850Si
System Memory: 6GB DDR3 1333MHz Corsair Dominator DHX (High-Performance)
Power Supply: 750W PC Power & Cooling (Dual SLI Compatible) (Silencer Edition)
Hard Drive Set 1: Operating System: 2x Two (320GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Hard Drive Set 2: Multimedia\Data: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Optical Drive 2: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) (LightScribe Edition)
Video Card: 1x NVIDIA GeForce GTX 260 896MB (216 Cores) (Includes PhysX Technology)
Enhancements: LCD Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade)
LCD Display: - No Thanks
Priority Build: - No Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Feb 2009 at 8:54pm
ticket number and the resolution you gonna be gaming at please
  Quote pascal333 Quote  Post ReplyReply bullet Posted: 16 Feb 2009 at 9:40pm
Ticket number 248330
I will probably play at 1280 by 960 unless I change monitors. I have a better one I may switch in that has dvi.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Feb 2009 at 9:55pm
OK but keep in mind we pick your GPU based on your resolution, if we pick one for 1280 by 960 and then next week you get a monitor that is 1900 x 1200 your GPU is gonna be too weak to pull the new resolution.
so you sure you want to go with 1280 by 960?
aslo what games will you be playing?
Edited by DST4ME - 16 Feb 2009 at 9:56pm
theyhm View Drop Down
  Quote theyhm Quote  Post ReplyReply bullet Posted: 17 Feb 2009 at 10:37am
How about a price range, before DST starts building you $4,000 systems.
  Quote pascal333 Quote  Post ReplyReply bullet Posted: 17 Feb 2009 at 12:12pm
My Samsung monitor runs nice on dvi at 1600x1200, so that might be my choice if I go up from 900x1200. 1024x1280 is another option. I have not used that monitor for games so am not sure what I will do, as I will also use it for business and darn that small type!!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Feb 2009 at 3:03pm
ok I build you a system that can handle 1900 x 1200
here you go Ticket# 248554 --- Price: $2819 (To see this build click here)
Power Supply: 1000W Silverstone OP1000-E (Dual/Triple/Quad SLI Compatible) (Silent Edition)
Hard Drive Set 1: Operating System: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: 1x NVIDIA GeForce GTX 295 1.792GB (Includes PhysX Technology)
your thoughts
  Quote pascal333 Quote  Post ReplyReply bullet Posted: 17 Feb 2009 at 8:17pm
I put the Zalman fans in my original build because I thought the DSO 850Si case with its native fans was not as well cooled as the HAF932 case with its native fans. I have not seen others taking the Zalman fans with the HAF case.
Just checking: Is the gain with the Zalmans enough to warrant their extra expense for overclocking in this case? And I reask my question about the the choice of this case when it is used as a side table...do you think it is "safe enough" with reasonable caution? (I guess you do from your suggestion... but I want to double check!)Wink
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Feb 2009 at 9:54pm
with the HAF you don't need any fans and you are good to go, for OC the v8 is gonna do 90% of the cooling, the case comes with all fans you need and it will do its just great.
never use any of your cases as a side table, these cases have fans on the top and need it open for air flow.
  Quote pascal333 Quote  Post ReplyReply bullet Posted: 17 Feb 2009 at 11:00pm
DST4ME...with the HAF you don't need any fans and you are good to go, for OC the v8 is gonna do 90% of the cooling, the case comes with all fans you need and it will do its just great.
Say DST4ME, the pictures of the 850Si case do not look as if there is an air flow from the top and they do not show any arrows indicating a top air flow. To double check...you say there is a fan in the TOP of the 850SI case that needs to be left open?? (I have not seen one in person.)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Feb 2009 at 12:29am
From what I understand the 850si is cm stacker
and here is a top view
Edited by DST4ME - 18 Feb 2009 at 12:30am
