A40 headset microphone not recognized
Post Date: 2015-12-04
Dukera View Drop Down
  Quote Dukera Quote  Post ReplyReply bullet Topic: A40 headset microphone not recognized
    Posted: 04 Dec 2015 at 5:31am
So I'm rebuilding my Digital Storm rig after a bad rollback from W10.
The system is now stable with Falcon BMS running without issues. Sound is good, joystick is recognized and Thrustmaster external Multi Function Displays are working.
As I fly online, I use Teamspeak to communicate with others and here lies the rub.
I cannot get a successful voice test in Teamspeak.
I have an A40 headset plugged into the front panel of a Create SB Recon 3D PCIe slot. There is sound in the headphones and if I unplug them, sound works in the computer external speakers.
In windows control panel, playback is Speakers as default device.
Recording is Digital-In (SB Recon3D PCIe) and What U Hear (SB Recon3D PCIe) both with green checks as default device. The microphone is shown as not plugged in.
In Creative Trustudio I have headphones selected (this works both with the headphones or external speakers for sound) and in the Crystalvoice tab, the mike is shown as disconnected.
I have the mike volume full up on the front control panel of the SB card.
Obviously I am not sure what I'm missing and could use a third eye on this.
Thanks in advance,
Dukera
  Quote Dukera Quote  Post ReplyReply bullet Posted: 04 Dec 2015 at 6:00am
More information - I unplugged the mike jack from the front of the SB I/O drive and plugged it into the back of the card - bingo, mike is connected and works in TeamSpeak.
What I don't understand is that prior to the rebuild, the entire headset and mike was plugged into the front I/O card and worked without any issues at all.
So any thoughts on what I may need to do to get back to that would be welcome.
Thanks,
Dukera
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 04 Dec 2015 at 8:14am
I don't do much with audio, but in the SB Control Panel , select Mixer I believe and see if the Front Panel box is available and select front panel for the Mic.  Or, Front Aux if an I/O.
Edit... here's the link I had from awhile ago I'm getting the info from.
http://support.creative.com/kb/ShowArticle.aspx?sid=102309
Hope this works. Big%20Smile
If still an issue, I would update the SB drivers for your device.  Switching between OS can mess things up.
Edited by bprat22 - 04 Dec 2015 at 8:19am
  Quote Dukera Quote  Post ReplyReply bullet Posted: 04 Dec 2015 at 2:07pm
bprat22 - thanks. That did the trick.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 04 Dec 2015 at 2:37pm
Good to hear.
