add another solid state hard drive
Post Date: 2015-04-04
olekrow View Drop Down
  Quote olekrow Quote  Post ReplyReply bullet Topic: add another solid state hard drive
    Posted: 04 Apr 2015 at 11:19am
I have a ODE V2-level 4 desk top:
would like to know if i can add another ssd drive?
Is this something i could do my self,i have installed a GPU,memory,sound card,but nothing i had to wire up?
Thank you Olekrow
Olekrow
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 04 Apr 2015 at 1:29pm
As long as your motherboard has an open SATA port, should be no problem.   You'd mount it, connect a Sata power connector from the psu wiring harness, connect a Sata data cable to the ssd and the other end to the motherboard. You might have an extra sata cable in your accessory box.
You'll probably have to go into disk management and initialze and format it.    That's it.
Pacesetter View Drop Down
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 04 Apr 2015 at 2:14pm
If you have the Samsung EVO and get either the EVO or PRO you should have a disc and/or get one with the new drive that has a program called "Samsung Magician". This program will set up your computer (drivers, etc), the drives (format, partition, raid) and get ya going fairly easily.
Vanquish II Ultimate.
  Quote olekrow Quote  Post ReplyReply bullet Posted: 04 Apr 2015 at 4:54pm
would a Samsung 850 pro 250GB work?
the mother board is a ASUS SABER TOOTH Z77.I have a120GB Corsair that is all most full which has the OS on it+a 1 TB western Digital.
Thanks very much for the information.
Olekrow
Olekrow
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 04 Apr 2015 at 5:06pm
Excellent drive.   That'll work just fine.
