Adding A Case Fan Need Advice
Post Date: 2012-08-02
rsmilford View Drop Down
  Quote rsmilford Quote  Post ReplyReply bullet Topic: Adding A Case Fan Need Advice
    Posted: 02 Aug 2012 at 12:21pm
Ok, so I have decided to add a case fan to my Old Silverstone TJ02 Window. This case has poor negative airflow and i plan on getting a little positive airflow with this upgrade.
I will be using a Cooler Master MegaFlow 200 Silent Fan (Intake)
I have already ordered the fan.
http://www.coolermaster.com/product.php?product_id=6492
And a 200mm x 230mm Silver Fan Grill (Outside of the window)
I have not ordered the Grill yet.
http://www.frozencpu.com/products/5318/ffg-22/200mm_x_230mm_Silver_Fan_Grill_-_Antec_Big_Boy_Cooler_Master.html?tl=g47c221s1053
My Question is what Hardware will i need to reach from the fan through the window and grill?
Am I taking the right approach?
Any suggestions or ideas are welcomed!
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 02 Aug 2012 at 12:31pm
Almost forgot the Specs
Build: 6724
SilverStone TJ02
Power Supply: 550W Corsair HX
Motherboard: nVidia 750i SLI FTW
Processor: Intel Core 2 Quad Q6600
Heatsink: Freezer Pro 7
Video Card: 560Ti 448 cores Classified Edition(EVGA)
Memory: Patriot PC2-8500 1066MHz 4GB
Hard Drive: 160GB Western Digital
  Quote FrankW Quote  Post ReplyReply bullet Posted: 02 Aug 2012 at 2:04pm
Hi rsmilford,
I am not a fan of the TJO2 case due to its limited cooling. I hope you added the rear 120mm fan already. It is a mistake that this rear fan is not included with the case.
The limitation you might have is the distance from the side plate to cards. This is a mid-sized case and is there room to mount the fan? Let us know how it turns out.
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 02 Aug 2012 at 2:29pm
This is what im working with i think its a TJ02 Maybe TJ04 I dunno its older 2008 on the receipt digital storm called it the 750Si Case
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 02 Aug 2012 at 2:48pm
I think i have enough room about 2 1/2 inches.
does anyone know what thread size the Cooler Master MegaFlow 200mmx200mmx30mm fan takes?
Edited by rsmilford - 02 Aug 2012 at 2:48pm
  Quote Alex Quote  Post ReplyReply bullet Posted: 02 Aug 2012 at 5:27pm
The best solution for that chassis is to drill 120mm holes for fan mounts.
Place them on the window.
xii View Drop Down
  Quote xii Quote  Post ReplyReply bullet Posted: 04 Aug 2012 at 2:11am
NIce deer.  The PC ran it over.  I approve.
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 08 Aug 2012 at 6:57pm
Success
I recommend using a Rotozip with a spiral cutting device for perfectly measured holes.
Edited by rsmilford - 08 Aug 2012 at 6:59pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 09 Aug 2012 at 5:19am
Nice job.  Big%20Smile
Edited by bprat22 - 09 Aug 2012 at 5:19am
  Quote Asangard Quote  Post ReplyReply bullet Posted: 09 Aug 2012 at 9:27am
congrats looks great Cool
shot View Drop Down
  Quote shot Quote  Post ReplyReply bullet Posted: 09 Aug 2012 at 12:35pm
From what I can see that really did turn out well.  OCD much?
Intel i7-8700k
ASUS ORG STRIX Z370-H
16GB DDR4 3000mhz DSPS
1000W Corsair HX1000i
SSD M.2 1TB 960 PRO
SSD 256GB 850 PRO
GTX 1080Ti 11GB
Sound Blaster Z
  Quote FrankW Quote  Post ReplyReply bullet Posted: 09 Aug 2012 at 12:53pm
rsmilford, that looks terrific. I can't even see the hole you cut into the plastic for the fan to draw air.
xii View Drop Down
  Quote xii Quote  Post ReplyReply bullet Posted: 09 Aug 2012 at 2:02pm
Wow... Fantastic work!  Wow.
This page was generated in 4.394531E-02 seconds.
