Adding a Hard Drive or another Optical Drive
Post Date: 2010-09-27
KJ View Drop Down
  Quote KJ Quote  Post ReplyReply bullet Topic: Adding a Hard Drive or another Optical Drive
    Posted: 27 Sep 2010 at 8:26pm
Hi All :)
Love my new PC but Here was my build shown below and wondered - it looks as if all my Sata's are spoken for ( 6 ) off the MB... but what if I want to add another Optical Drive - I have the power but where to pick off another Sata connection ?
I see where 2 go to my existing drives(OS and Data) , 1 goes to front panel of the HAF X  case for outside access,  1 goes to the existing optical drive and 2 go to a small Board toward the front of the HAF x - for the Sata Docks -
Do I have to rob one of those Sata connectors that feed the 2  Sata Docks ?
Big%20Smile
Thanks Much folks
Ken
Motherboard: EVGA X58 LE Edition SLI (Intel X58 Chipset)
System Memory: 6GB DDR3 1600MHz Digital Storm Certified
Power Supply: 1200W Digital Storm Certified (Dual/Triple/Quad SLI Compatible)
Hard Drive Set 1: Operating System: 1x (80GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance)
Extreme Cooling: AIR: Stage 2: Noctua NH-D14 Extreme Performance
AndydViking View Drop Down
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 28 Sep 2010 at 3:07am
You might wanna look into internal sata card? I have not used any so i don't know any good ones to recommend.
I'd prolly just take one of the hot swap ports or esata one out and just use that. Though if you don't like that idea their are those cards I said about.
This page was generated in 2.441406E-02 seconds.
