Adding Bluetooth Card to Lynx Level 4
Post Date: 2019-12-16
crispy9492 View Drop Down
  Quote crispy9492 Quote  Post ReplyReply bullet Topic: Adding Bluetooth Card to Lynx Level 4
    Posted: 16 Dec 2019 at 11:26am
So I bought A lynx level 4. I wanna be able to use my laptop as a 2nd monitor but thats only available if bluetooth is built in(which it isnt but should be considering its a 1500$ ultimate config) I need suggestions on which one will fit. Youtube vids will help me install it. Just dont know which one I should buy...
Edited by crispy9492 - 16 Dec 2019 at 11:51am
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 16 Dec 2019 at 5:25pm
ASUS makes some good Bluetooth PPCIE cards and USB adapters.
  Quote crispy9492 Quote  Post ReplyReply bullet Posted: 17 Dec 2019 at 8:51am
I dont want an adapter. I want a card I can install to the motherboard. I just dont know which one too look for or get that will fit in my lynx level 4. I Need suggestions or preferably post some links to some that'll work
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 17 Dec 2019 at 10:58am
A PCIE card is also an adapter.   Most cards will have both WiFi and Bluetooth on one card.   I don’t know what motherboard you have in your build, but the example shown has just one full size PCIE graphics card slot, and all the other PCIE slots will be the short slots...that’s where the card you want will mount.
The latest version of BlueTooth is 5.0.
Amazon has quite a few that would work.   Search on Bluetooth 5.0 PCIE card.
CarrieOnTheWeb View Drop Down
  Quote CarrieOnTheWeb Quote  Post ReplyReply bullet Posted: 14 Nov 2020 at 8:41pm
I am having the same issue, would buying this help?
https://www.amazon.com/dp/B089Q8KX98?tag=amz-mkt-chr-us-20&ascsubtag=1ba00-01000-org00-win10-other-nomod-us000-pcomp-feature-rscomp-wm-5&ref=aa_rscomp
--beepbopboooop
  Quote Cretae Quote  Post ReplyReply bullet Posted: 15 Nov 2020 at 5:34am
Not my area. The OP didn't want just a USB dongle, but I DK why. What I saw was the dongle being good for periferals like keyboards, mice and printers, etc. but streaming to a laptop's monitor wasn't mentioned. If no one else knows, I'm sure DS could tell you.
